Presto Model Y Lathe
- Presto Repairs
Hi Trolls,
2 days ago I was fortunate enough to aquire a very rare find...
A Presto Model Y record lathe with Australian 240v power source originating from one of australias leading am radio stations
Ive begun rebuilding it & discovered that the power switch and the mic switch were bypassed by the previous owner
I corrected the wiring and while flicking the power switch on and off repeatedly, the double cap for the motor failed
Ive priced several suitable replacement caps - Just havnt decided on which one yet
Aside from this and the mounting bushes for the motor, everything else appears to be fine... Platter + motor ran smooth and quiet until the cap went, the belt around the platter is soft and has no cracks in it, the cutter feed mechanism runs smooth and quiet with no wobble for both outside in and inside out
The 1C cutter didnt come with the lathe, but will permanently fitted unless the 1D on my 116-E overhead fails
I will be building a new timber box base for it and I am also looking into getting a perspex top formed for it...
Presto Repairs - Repair/Restoration service for Presto Recording Corp cutterheads and other similar styled brands such as Audax, RCA & Universal
Re: Presto Model Y Lathe
Nice find. Well done.
- Presto Repairs
Thanks Aussie,
I've temporarily replaced the cap with a cheapy from my local electronics shop and got it running again
Ive ordered N.O.S Replacements - Should be here in about 2 weeks...
Ive conducted a thorough inspection of the lathe and found 2 small flat spots + 1 chip on the platters rim rubber
I turned the rubber inside out and was able to clean up 33 and maintain good torque
running at 78 cleanly could only be achieved with the capstan running lightly against the rim enough for playback but not enough to cut - Too much and you could hear the flat spots
I am currently looking at two places to get a true endless flat bet to replace the rim rubber
I also need to replace the motors mounting bushes as they are old + Give the motor a service and get it running super quiet
I recorded a little bit of video last night and flicked it up on you tube - I had to limit the time because there were idiots racing eachother in their cars around our local area at the time I was recording
Presto Model Y Record Lathe - Run Test: http://youtu.be/lLFesDxIz6g
- Presto Repairs
So far the rebuild has been going smoothly...
I've replaced the power cord and wiring throughout
Ive also replaced the toggle switches and even added a power light bezel
Funds are allocated to cutterhead supplies at the moment so the new flatbelt for the platter has to wait...
Ive also been thinking about making a new brass spindle pot for the platter and bearing to make the turntable run like brand new again
If I make a new one and it works well - I will consider making others
Also - I have to correct myself regarding the lathes model number...
What I have is actually a Presto 75-A Recording turntable with a 240v BRS motor
The model Y was a package (75-A turntable, 87-A Amp & Loudspeaker)
I only have the turntable....
The BRS motor is the same type of motor used in Byer turntables which were manufactured right here in melbourne australia...
- Presto Repairs
Not long until my 75A is gets fitted to its new home...
I decided to do the new base out of 32mm mdf, I had enough material to do 3 bases so if anbody is interested in a new heavy duty base for their 75A Send me a P.M
- Lima Victor
Don't forget metalized paper capacitors also degrade when they are unused in storage. Paper submersed in oil is more reliable. However, modern plastic foil diëlectrum capacitors have the longest life.
Hi there. Digging up an old post here. I have recently acquired a Presto 10A turntable, and am chasing some info. It runs well at both 78 and 33 speeds, but the rim tyre is cracked and unsalvageable, making it noisy during operation. Any idea on replacement options? I’m in Australia so trying to chase up pool pump seals as discussed in another post isn’t really a practical option for me.
Search "Terry's Rubber Rollers" here. Chances are he's already made one and has the specs, otherwise you'll have to send it to him in the USA. Very good to deal with.
Thanks for the info. I was hoping there may have been someone in Oz that someone had sourced. I’ll look into Terry’s and see how it goes. Cheers.
- EvLoutonian
How did you go with this?
I have some old Aussie broadcast turntables I've been meaning to source parts for for rest etc.
Good to know any Australian resources.
Cheers,
Evan
