Hey trolls.
Every so often, I run into a clogging issue with our VR vacuum system and I just can't figure out why it's happening. I've tried all the tricks that I know about - And yes I've seen Opcode66's plastic cutting guide - but I was wondering if this is just par for the cutting course or if I'm just totally missing something. I doesn't bother me often, but 3 times today on side B of a 40 minute LP reallllly get's me fired up! Oof..
Any insight and or moral support is welcomed.
Cheers,
J
Vacuum Tube Clogging Issue VR
Re: Vacuum Tube Clogging Issue VR
I find the same thing, usually I spray a little anti static when I see it start to lose pickup.
or at the least, brush the chip out of the way to save the cut.
I find that once chip starts falling on a plastic cut, the cut is wasted. You can hear noise where the chip was interfering with the cutting process. Since the plastic tends to ball up right around the stylus point typically, unlike with lacquer.
I find that using an ionizer on the disc before cutting helps. Also, run some talcum powder through your vacuum system. It helps to reduce friction and cause static in the tube.
Watch my plastic cutting guide.
