Vinylrecorder signal chain question
- MightyRecords
Hey everybody,
I have a question for VR owners, any help would be greatly appreciated.
I am having troubles getting a stereo signal for cutting or playback, everything is mono. I believe I have done something wrong when splitting the signal coming out of the mixer.
I have attached an image of my current signal chain after the mixer. Is this correct?
How can I get both the Main Unit input and the Mixer Line 1 to have stereo signals?
Thanks,
Andrew
Thanks,
Andrew
Re: Vinylrecorder signal chain question
From your drawing, it looks like you are feeding the L (black) mixer output to the line input of the mixer (for monitoring) and the other (R/red) output to the main unit. Imagine your drawing but with the splitters connected at the mixer output, that would give you two stereo pairs. Connect up so that one L/R pair goes to the mixer and the other pair goes to the main unit.
Does that make sense?
- MightyRecords
Thank for responding!
Collectively there are 4 male ends to the splitters ( 2 x Black + Red), but only two female output jacks on the mixer. Which of the 4 splitter jacks do I connect at the mixer output? Should it look something like this? (i'm pretty sure I'm way off here ):
I am definitely overcomplicating this. If anybody has a chance to upload a picture of the back of their mixer, I would really appreciate it.
Cheers,
Andrew
Cheers,
Andrew
You can ask souri from vinylrecorder.com ?
I can't tell if your RCA is TO or FROM the main unit?
this is one of the reasons why I removed the mixer from my chain all together
