Cutting PVC/PC/Pressed blanks etc. on a Vinylium Cutter?
Hi everyone,
Is there anyone out there cutting these type of discs using a diamond stylus on a Vinylium machine?
I've seen a few videos of it on you tube, but I'm sure I read somewhere that the angle of the cutter head needs to be somehow changed on a Vinylium in order to use a diamond stylus? Did I dream it or is that in fact the case?
Also, if it is possible, could someone suggest a good source of discs and diamonds?
Thanks in advance for any help.
Re: Cutting PVC/PC/Pressed blanks etc. on a Vinylium Cutter?
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
Hi there,
About that, you just need a new holder as the one you can see on the picture for your SC99 to adjust height and angle, that's all... then, a DIY suction system, and you'll be able to cut plastic with diamonds.
![Image](http://img11.hostingpics.net/pics/338836IMG3185.jpg)
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
Thanks Myshank,
Your time and answer is very much appreciated. I checked out your website and if I get this going I will come to you for blanks and diamonds.... Thank you.
Because I want to cut both lacquers & PC discs, and the fact that I know a great toolmaker.... Rather than swap a whole component out every time I want to switch between the two formats, would it be possible to get my guy to make a kind of angled shim that the cutter head screws into (with obviously the shim attaching to the overhead the way the cutter head would usually do) ? This seems like a slightly less ball ache solution, or am I missing something obviously?
Also, why would I need to change the height as you mentioned, this is something I don't understand either..
Thanks so much for your help
Mudshark
Mudshark
PVC cutting and lacquers cutting are not cutting to the same angle... So you would have some change to from one to an other...Mudshark wrote:Thanks Myshank,
Mudshark
With the alu part you see on the picture, you can adjust the head to the angle you want... but if you change angle, you obviously have to change the height of the head. When pulled down
on your blank (whatever the blank), you always need to be on the famous imaginary line from the inner to outer perpendicular to the mirror face of your stylus.
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
Ok I get that, thank you. Leads me to the obvious question... Is anyone making these, or does anyone have drawings of it so I can get one made? Thanks.
Look at the alu parts on the pics and do the same by yourselfMudshark wrote:Ok I get that, thank you. Leads me to the obvious question... Is anyone making these, or does anyone have drawings of it so I can get one made? Thanks.
![Wink ;)](./images/smilies/icon_wink.gif)
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
