NEW German record lathes?
Post: # 2208Unread post piaptk
Fri Jan 25, 2008 3:48 am
Hi, I remember years ago, someone pointing me in the direction of a German company that is making new record lathes. They were in the $7K range, and although I really can't afford it, I would like to check out the site again. I've bought a couple of bunk lathes on ebay in the hopes of getting a working one, and am almost to the point of selling my car to buy a lathe that I know will work. Does anyone know the name of this company? (or someone getting rid of a working lathe that I can get cheaper)?
blight
Post: # 2209Unread post blight
Fri Jan 25, 2008 8:13 am
www.vinylrecorder.com
But don't think you just have to plug it and it will work...
Some people seem to believe that this machine does NOT work because THEY are not able to set it up correctly.
Maybe you could also get some old Presto because the vinylrecorder isnt cheap (if you get a vinylrecorder, buy the precision plate immediately! it helps a lot!)
vinylrecorder is the only one with which you can cut into vinyl-like blanks (with a diamond stylus)
The machine costs about 3K, but you need a few more K for everything else which you need - so in the end you will pay about 7-15K for your whole system.
hth
jo)))
also
Post: # 2210Unread post jo)))
Fri Jan 25, 2008 10:08 am
check out
www (dot) vestax (dot) com
they have a cool one in the recorders section, would post link but I am not allowed yet.
blight
Post: # 2213Unread post blight
Sat Jan 26, 2008 9:36 am
lol, the vestax! i would stay away from it, just search on youtube for vestax and you will find a video called "cutting a record with the fucking shit vestax" or something - that tells everything...
motorino
Post: # 2214Unread post motorino
Sat Jan 26, 2008 12:59 pm
hi
marcosrobotik http://www.youtube.com/watch?v=50fhueFWpaw
and trackCdental http://www.youtube.com/watch?v=mQ9jB-36Y60 its the same men....me
Now, Andybee http://www.andybeemusic.de/ sells diamonds for cut pvc, you can fit in neumann and Vinylium cutterheads (and westrex haeco with the transco stylus adapter)
Look http://www.vinylium.ch/dubcut/dubcutter.html, much better machine than vinylrecorder
Doug6N
Record Lathes
Post: # 2215Unread post Doug6N
Sat Jan 26, 2008 7:26 pm
Hi:
Just my two cents worth here. I suspect 95% of the battle in record cutting is total understanding of the equipment and how to properly use it.
Good cuts can be made with most vintage proffessional equipment and even pretty decent cuts on the home equipment.
A good working knowlege of both electronics and mechanics is in order to do this. It's not for the feint of heart. :)
This equipment I doubt will just work when we get it. I've not had that experience yet. :D
It can take hours of study and practice and talking with others to do this successfully. I'm still learning and yes I've had my share of very costly errors. Like breaking the stylus first time out. :( We alll have here I'm sure.
Nothing bad intended. Just the facts :)
Doug
Amp Doc
Post: # 2217Unread post Amp Doc
Sun Jan 27, 2008 3:46 pm
Two broke styli, one toasted presto head and 10 posh tea cup mats at £10 a pop and I then I got a cut worth hearing. Exspensive learning curve :shock:
But was worth it and every time I cut a track it gives me a sense of acumplishment...shame I cant spell still :lol: :lol:
I still am suprised how a vintage grampian head with a home brew amp can sound. I have cut a track and had people not be able to tell the cd master or cut track apart :D
!Work or Bang Time!
motorino
Post: # 2244Unread post motorino
Tue Feb 05, 2008 5:24 pm
im surprised too with my grampian, cutting without feedback its incredible....i use a yamaha Q2031B for the recording riaa
i made some cuts testing all......and sounds good, the amp its a 80s DAS recapped, 300w for driving horns in a I rider PA, very good amp
