Harara [Hara] portable lathe
Re: Harara [Hara] portable lathe
There is a great app called “RPM” that we use. But your accelerometer in your phone isn’t super accurate, so you have to test it on a 1200 to see what speed it’s reading on a turntable you KNOW is at 33.3. My app reads about 33.6 when it’s spinning at 33.3.
Beautiful Machine
- sgreiner1011
My Hara M-180 is supposed to run at 45rpm but it actually runs at about 57rpm with the 100V transformer. I use Audacity and I speed the song up to about 25.8% before I cut. Sounds beautiful when playing on a 45rpm turntable when the amp in the lathe wants to work right.
do you use a voltage converter from 120 to 100? I got a hara recently and wondering if I need one. the amp buzzes like mad. I'm wondering if maybe it has some blown caps or if the voltage difference is a problem.sgreiner1011 wrote:My Hara M-180 is supposed to run at 45rpm but it actually runs at about 57rpm with the 100V transformer. I use Audacity and I speed the song up to about 25.8% before I cut. Sounds beautiful when playing on a 45rpm turntable when the amp in the lathe wants to work right.
who cut one?
