Anti static liquid
kafkablues
Anti static liquid
Post: # 45484Unread post kafkablues
Sat Jan 07, 2017 3:18 pm
Hi folks, some quick tips on using my Shank anti static liquid would be greatly appreciated ie how much to use, type of cloth (if needed), how long to leave on ect. Thanks.
KNOP
Re: Anti static liquid
Post: # 45495Unread post KNOP
Sun Jan 08, 2017 9:26 am
I use makeup remover cotton pads. I just hold one against the bottle, then while the turntable is spinning gently wipe across the blank, then direct start cutting. I'm not sure this is the proper way, but works for me.
kafkablues
Post: # 45505Unread post kafkablues
Sun Jan 08, 2017 6:37 pm
Cheers. Do I do go from outside to inside before cutting or do the wiping whilst cutting?
aaron
Post: # 45510Unread post aaron
Mon Jan 09, 2017 7:27 am
I do the same, with a cotton ball, outside to inside while it's spinning until the blank is coated. Wait to dry, start cutting.
kafkablues
Post: # 45511Unread post kafkablues
Mon Jan 09, 2017 7:37 am
Wait to dry. Excellent advice. I was just about to crack on, cutting immediately after applying liquid. Much appreciated.
tapesandtubes
Post: # 45553Unread post tapesandtubes
Thu Jan 12, 2017 10:01 am
This is well worth reading. Although, it's not specific to MyShank--it's incredibly helpful regardless.
http://www.deepgroovesmastering.com/share/Plastic_Cutting_Guide.pdf
Presto K8 | 6N
kafkablues
Post: # 45555Unread post kafkablues
Thu Jan 12, 2017 11:14 am
Many thanks. I have come across his and I've been using it like a bible.
I think Iv sussed it now. Got myself a little air purifying ioniser for £15 from eBay. With regards to the liquid I've been using cotton wool pads going back and forth from the edge right upto the hole, and then squeezing the liquid onto to disk, particularly around the outer side, as this area seems to have the most static.
The only thing I don't have with regards to the guide is a heat lamp. If anyone can recommend one it would be appreciated.
Regards.
