Neumann SA74 Suspension Box Help
Moderators: piaptk, mossboss, Aussie0zborn, tragwag, Steve E., Simon
Unread postby pandapolar » Sun Mar 19, 2017 9:50 pm
Hi Trolls
We are doing up an SA74 and need some help (photos would be great) ...
In the SB the CutterHead Dropping Lever works as per normal, dropping the head down, but there is nothing to keep the lever engaged and the head (and lever) returns back to the up position.
when looking inside the SB, specifically at the Cutter Lift Button, there is nothing to link the lever and the lift button... i assume we have a part missing... ??
thanks guys
pandapolar
Re: Neumann SA74 Suspension Box Help
Unread postby tubefan » Mon Mar 20, 2017 1:17 am
There's a bar actuated by a solenoid that is spring loaded and engages a piece on the shaft that the drop lever is attached to. You can see it from the left side of the box (where the mounting nut is) with the side cover removed. Sometimes the mounting bracket is out of adjustment, it's held with two screws.
tubefan
Unread postby pandapolar » Mon Mar 20, 2017 5:55 pm
heres some pics
pandapolar
Unread postby tubefan » Mon Mar 27, 2017 5:48 pm
Wow, you're missing the solenoid with the bar completely...
tubefan
Unread postby pandapolar » Mon Mar 27, 2017 6:11 pm
tubefan wrote:Wow, you're missing the solenoid with the bar completely...
you wouldnt happen to have a photo???
pandapolar
Return to Secrets of the Lathe Trolls
Who is online
Users browsing this forum: Bing [Bot] and 6 guests
