![Image](http://i36.photobucket.com/albums/e1/Ariel_Tagar/IMG_3420_zpsxnl7v2mo.jpg)
Hi everybody,
A Couple of days ago I came back from Japan with my new Hara M-180 lathe! (7"). My model comes with a build in tonearm which is prob rarer than the regular smaller model. All very exciting!
I spent the night cutting some tests and encountered an issue, hope you guys can advise me!
I am cutting Suri PVC blanks using Turtle wax, Heat to 100 deg f, a 100W step up adaptor to 220 on 50 HZ. All by the book via what I read here.
I started with the old stylus which came with the lathe. When playing it back, the cut sounded great and clean in the beginning, after about 30 seconds I began to hear an increasing noise/hiss, which then stays on other cuts.
I replaced the stylus to the Russian stylus I bought from ebay (will splash on a Myshank stylus after I get some experience), this time without the heat cord, and same thing, first 20-30 secs are good, then comes the noise which stays.
I thought maybe I was putting too much pressure on the stylus and quickly damaging it, so I lifted the arm pressure a little and it sounded horrible so put it back to its previous position - but the hiss/noise is back.
Any thoughts as to why this happens? Again, the first few seconds on both styluses sounded nice and clean and only then the noise/hiss comes.
Am I a serial stylus destroyer? What can I do to prevent this? The Hara adjustments are minimal, only groove space and height (hight adj is very fiddely and un accurate, its just a screw in the back of the cutter head's base which is more for releasing it from its base. It's almost like yr not supposed to adjust it.
Any thoughts/help appreciated!
Thank you!
Anton
Cutter head close up + Russian Stylus
![Image](http://i36.photobucket.com/albums/e1/Ariel_Tagar/IMG_3419_zpsqdvgvpnc.jpg)
Old stylus +heating cord
![Image](http://i36.photobucket.com/albums/e1/Ariel_Tagar/IMG_3421_zps4nyd9ltv.jpg)
