wax is there any better?
- fredbissnette
is there anything better than turtle wax?
ive tried all kinds of shit
turtle works great but is there anything better?
Re: wax is there any better?
I use nu finish orange can. Works great you just gotta spread it, heat it and wipe it smooth
- fredbissnette
Yes, there is. ACL Staticide Heavy Duty is 'the shit'. I originally dismissed it in favour of my own home brew but all my ingredients ran out and a gallon of this stuff worked out cheaper than a re-up so I gave it a shot. I won't be using anything else! It's actually made to meet military specifications for killing static on non-conductive, non-porous surfaces (such as plastic) in dry environments.
Combined with a Reitschle VTE-8 vacuum pump, I'm about 500 sides in without a single bit of dropped swarf (chip). Evaporates quickly! No streaking! Also smells kind of nice, in a 'this must be bad for you' way...
Digi-Key stock it.
Digi-Key stock it.
- 2bitcomputer
I also use Staticide and find it to be very effective - I use the 'normal strength' which is available on Amazon:
https://www.amazon.com/gp/product/B00BR55KQ6/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I haven't tried the 'heavy duty' version...
No build up on the diamond with Staticide??
I asked someone here a while ago about this and the answer was very positive for Staticide.
- fredbissnette
i generally leave mine on during cutting so can you do this with the staticide?
- 2bitcomputer
@ben I have never seen buildup on the diamond, it wipes off cleaner than souris secret sauce.
@fredbissnette I have no experience embossing - just cutting with a diamond - so I don't know if staticide will work with embossing.
For cutting I spread it on the spinning blank really thin with a microfiber cloth then I wait for it to evaporate off the surface - takes 10 seconds - then I start the cut.
- fredbissnette
yeah that wont work for embossing unless you have a very well balanced cutterhead
i was wiping my wax off but then i had squeaks so now i leave it on
the wax also softens the discs
cheers thanks
cheers thanks
