Oreo records :)
Oldskoolhousehead
Oreo records :)
Post: # 47884Unread post Oldskoolhousehead
Thu Sep 21, 2017 9:44 am
Hey guys, i'd like to share a link with you. I hope you like it.
https://vimeo.com/165258770
Re: Oreo records :)
Post: # 47887Unread post tragwag
Thu Sep 21, 2017 10:43 am
wow this is something else!
Re: Oreo records :)
Post: # 47888Unread post markrob
Thu Sep 21, 2017 11:05 am
At first glance, this seems pretty cool. But if you look at the video carefully, you will see that they did not really cut audio into a cookie. First, there is no spiral baked into the cookie (a single locked groove is baked). If you look at the block diagram, you can see that they are using an Arduino Uno to run a small turntable motor and playback some digital audio stored in the a program via a speaker connected to a port on the board. The Arduino just senses the location of the arm and once its in place the motor starts and the audio playback begins. If you look at the cookie rotation speed, there are many revolutions of the locked groove with a much longer audio program that would be possible given the time per revolution.
Still a fun marketing stunt. I wonder how many were made.
diamone
Re: Oreo records :)
Post: # 47967Unread post diamone
Sat Sep 30, 2017 2:40 pm
