G.E. PLAY TALK RECORDER DISCS
MALOS
Post: # 2716Unread post MALOS
Fri May 02, 2008 12:37 pm
“Playtalk” electronic toy for children uses a grooveless paper disk coated with “powdered” iron to record and reproduce magnetically music or voice. Records hold about two minutes of recording; can be “erased” and reused often
THIS IS WHAT i'M LOOKING FOR I need extra discs to release music on this dead piece of media and to use in a live performance setting. if anyone out there has some of these kicking around please let me know..
or if anyone know where I would be able to buy a can of spray-on powdered iron? (Does this type of product exsist??)
please email me at wintagerecords@gmail.com
WINTAGE RECORDS & TAPES
1530 QUEEN ST W C-3
TORONTO, ON.
M6R 1A6
CANADA
blacknwhite
Post: # 2720Unread post blacknwhite
Fri May 02, 2008 11:26 pm
Have you tried just using old magnetic computer so-called "floppy discs", pulling them out of their protective jackets? ("floppy discs" were individual removable magnetic data-storage discs for home computers - the forerunner of data CD's)
I don't know what diameter the records are supposed to be, but there are still tons of factory-sealed 5-1/4 inch floppy discs out there on ebay cheap.
Worth a try...
- Bob
tape
Post: # 2743Unread post tape
Mon May 05, 2008 5:04 pm
that media would be standard magnetic tape:-), just circleshaped.
I have an old dicthaphone that uses this priciple.
You would be releasing on a medium that nobody will be able to play back...but good luck!
FStephenMasek
Post: # 3188Unread post FStephenMasek
Fri Jul 25, 2008 9:58 pm
Did you ever find discs?
I have found one of the Playtalk units, and see that GE made 5,000 of them in 1949.
With rare exceptions, less government = more freedom, more hapiness, and more prosperity
alienmanstk
Post: # 3359Unread post alienmanstk
Thu Aug 21, 2008 10:16 pm
hey guys , check on ebay, there is one that just went up, starting at $150, but its in great shape, only problem......no disks! well, i bet those can be reproduced anyway, with all these great minds on here!!!! good luck!
motorino
Post: # 3360Unread post motorino
Thu Aug 21, 2008 11:28 pm
diamone
Re: G.E. PLAY TALK RECORDER DISCS
Post: # 32411Unread post diamone
Wed Nov 26, 2014 3:52 pm
Anybody ever find or make some discs? I'd have used the old computer floppy discs taken out of the case as well - except I'd have used the 8-inch version and then re-made my spiral to accommodate the larger size - along with a template to support the extra width from underneath.
