Smooth blank edges
Smooth blank edges
On Souris training weekend I remember him showing us a way to ‘smooth’ the edges of the blank so they aren’t so squared.
I have completely forgotten the technique as to how do it. I remember he basically just scraped a knife across it but I can’t get it to work!
Any help appreciated!
- petermontg
Re: Smooth blank edges
Get yourself a vegetable peeler and run it along the edge.
Best
Peter
Best
Peter
Peter Montgomery
+353(0)894926271
+353(0)894926271
Is that in jest?
At the moment I'm spinning my polycarb blanks on a juicer motor and sanding them by hand...
- socialroots
Check out Myshank,Stevens got something on there just to do what want. The peeler probably will work as well,but probably one side at a time. Ive done it before just with scissors sharp edge,but i dont even bother anymore,the square edge is fine for me,dont need the extra work n extra plastic shavings messing up my work space or workflow.
the proper name is a plastic de-burr tool
here's the one I use these days after trying and breaking a cheaper one:
https://www.google.com/aclk?sa=l&ai=DChcSEwjXvsjRncTZAhWEJYEKHensDW0YABAPGgJ5dw&sig=AOD64_2dWmTTPOdzxCcZSJBNAZyEdgB0AQ&ctype=5&q=&ved=0ahUKEwiVksPRncTZAhVL2VMKHQ-fAJ0Q9aACCEU&adurl=
- Voxster1965
tragwag speaks the truth - the Mango is the go-to deburring tool - works like a charm.
+1 for the deburring tool, though I like the double one:
https://www.accu.co.uk/en/deburring-handle-and-blade-sets/451992-155-00206
I was using a Stanley knife (box cutter) blade and it worked fine, but I managed to stab myself with it a couple of times and (most) people don't want blood on their records.
I would also recommend wearing a dust mask. As you drag that blade across the brittle edge of the disc, there is an explosion of invisible fine powder for you to inhale, likely to result in respiratory problems in later life. You definitely do not want Pneumoconiosis in 10 years time!
ooooh! thanks for the tip on the mask, gotta do that from now onhandcut wrote:+1 for the deburring tool, though I like the double one:
Thanks for the suggestions. I forgot to check back for a couple of days and am chuffed to see so many helpful replies!!!
I think the de burrer is the safest option, it’s not just customers that don’t want my blood on their discs, I would rather not lose any blood at all!
Thanks handcut for the mask advice. It’s the little things I never think of.
Cheers guys
Cheers guys
- chrisdexta
I took the advice and got a double deburring tool, but having troubles using it... am I missing something?
I got one of these but there seems to be a knack to using it, you will start off trying to take off to much and it will bite right in and make jagged edges, seems little pressure and the right angle just to take enough off
- chrisdexta
Thanks, yeah i am finding that even the slightest bit of pressure digs right into the edge and just destroys the edge.DJ2000 wrote:I got one of these but there seems to be a knack to using it, you will start off trying to take off to much and it will bite right in and make jagged edges, seems little pressure and the right angle just to take enough off
would be great to see some kind of instructional video perhaps?
- onemiletar
Placing the blank on an old turntable to preheat while I am cutting one on the VR. Heating them up at around 30celsius, also for cutting
Then I am placing a knife on the edge and slowly turning the platter by hand.
Video here: https://www.dropbox.com/scl/fi/k126n8nckf4tgru4o0x62/IMG_3750.MOV?rlkey=m25o0nybxe5tybel6uua6xlvz&dl=0
I am sending this to friends telling them: << this is what I mean when I say I am "cutting vinyl" >>
I bought a Victorinox knife sharpener and it works a treat! google it
