Atom Vanrock, supply voltage?
dubplatecutter
Post: # 50200Unread post dubplatecutter
Tue May 01, 2018 2:26 pm
Hi everybody!
i just bought a atom/vanrock cutter from japan. today the machine arrived and it looks great. but now i'm not shure about the supply voltage.
it works on 100v. it is very difficult to find a step down converter from 230v to 100v / 100w max.
does anybody have this machine, and what a converter you use? can i go for a 110v one?
sorry for my english., but i think it's ok to get thru this.
cheers dude's.
peter
rsimms3
Re: Atom Vanrock, supply voltage?
Post: # 50201Unread post rsimms3
Tue May 01, 2018 4:15 pm
Check eBay for makers/models that you can then research quality on as well as pricing. I found a couple listings over there for 230v to 100v step down transformers.
Post: # 50203Unread post markrob
Tue May 01, 2018 6:17 pm
Maybe these multipurpose transformers by Signal will work for you. They can be wired for many voltages. Looks to me like the 200 VA unit (part number MPI-200-230) will do the trick. Use 230 Vac secondary and the primary strapped in parallel for 100 Vac and run backwards.
MPI.pdf
dubplatecutter
Post: # 50257Unread post dubplatecutter
Sun May 06, 2018 4:33 am
Hi Trolls! i found from the company airlink a step down converter in a online shop. thank you very much for your help!
if somebody needs this to, here's the link:
https://airlinktransformers.com/product/japan-europe-voltage-converter-eu-ja0250
now, the machine is running.., but the first cut's i did so far, sound not good at all. very loud acoustic backnoise.
maby i try another stylus from myshank.com
has anybody of you experience with different stylus for this machine?
happy sunday dude's!
ilium
Post: # 50262Unread post ilium
Mon May 07, 2018 1:58 pm
dubplatecutter wrote:Hi everybody!
I'm using this one for my Vanrock
https://www.amazon.com/gp/product/B000PC4JL4
discosdecorte
Post: # 53328Unread post discosdecorte
Mon Jun 10, 2019 5:02 pm
Hi!
I've just purchased an ATOM A-101. I haven't received it yet (fingers crossed!), but I'm already looking for a 230V to 100V step down transformer,as I live in Spain.
ATOM A-101 power panel:
What do you think about this transformer?
https://www.ebay.es/itm/50-Watt-AC-Voltage-Converter-Transformer-50W-220V-230V-240V-Step-Down-100V-Japan/323818367746?hash=item4b65142b02:g:uJoAAOSwbUdc64be
Best regards,
Fer
๐Ÿ„ณ๐Ÿ„ธ๐Ÿ…‚๐Ÿ„ฒ๐Ÿ„พ๐Ÿ…‚ ๐Ÿ„ณ๐Ÿ„ด ๐Ÿ„ฒ๐Ÿ„พ๐Ÿ…๐Ÿ…ƒ๐Ÿ„ด
mrd
Post: # 53343Unread post mrd
Wed Jun 12, 2019 4:42 am
i use this one and it works well - https://soundgas.com/product/airlink-japanese-uk-step-down-transformer/ works great. 100va (grey one)
discosdecorte
Post: # 53350Unread post discosdecorte
Wed Jun 12, 2019 4:04 pm
mrd wrote:i use this one and it works well - https://soundgas.com/product/airlink-japanese-uk-step-down-transformer/ works great. 100va (grey one)
Thank you very much! It looks much safer than the one I posted before :oops:
Any other alternartive?
Regards,
Fer
Fela Borbone
Post: # 53351Unread post Fela Borbone
Wed Jun 12, 2019 6:55 pm
In the spanish flea markets,is very common to find this old voltage regulators used for TVs some decades ago...They usually have several voltage options, meter and they look vintage too!
I use one in my Rek o Kut and works fine!
Saludos.
Fela Borbone
Post: # 53352Unread post Fela Borbone
Wed Jun 12, 2019 7:02 pm
Like this
discosdecorte
Post: # 53400Unread post discosdecorte
Mon Jun 17, 2019 11:27 am
Hi!
I've finally purchased one one those.
Thanks again :)
mrd
Post: # 53417Unread post mrd
Tue Jun 18, 2019 6:13 am
No problem, glad you got it sorted :)
