Caruso Head
Dubwise
Caruso Head
Post: # 50270Unread post Dubwise
Tue May 08, 2018 5:39 am
Hello Trolls,
Is anyone here using flo's caruso head with the T560?
What is involved to make this modification? Would Souris main unit need bypassing..
I have contacted Flo directly to see if the head is available, just awaiting his reply
Best,
Dub 8)
descent
Re: Caruso Head
Post: # 50288Unread post descent
Wed May 09, 2018 9:34 pm
Hello, info us if you will recieve a reply. I have the same modification in my plan.
Re: Caruso Head
Post: # 50309Unread post tragwag
Fri May 11, 2018 2:50 pm
Flo will tell you more specifically, but I've noticed the Caruso does have it's own preamp boards, all audio would likely go through there and bypass souri's main unit
flozki
Re: Caruso Head
Post: # 50333Unread post flozki
Tue May 15, 2018 4:02 am
i dont want you to encourage to upgrade your wonderfull vr system
but if you want to play away from home
here a small step to step guide.
for an upgrade you need:
- dump the original electronics. or use as a doorstopper. i know its hard to send this wonderfull engineered highlight in germany audio technology to recycling. but your sound deserves it.
(in fact all the electronics except the motor control is not used anymore. amp.head.cables.)
- order a caruso head. sadly i wait for a few more parts until you can get a new one. but there is light at the end of the tunnel.
- build your own caruso preamps. or buy ready to use & tested preamp boards and build them into a case with a +/-15V power supply.
- buy a descent power amp with 26dB gain.and approx 100-200W per channel. QSC GX3 works great. there might be better stuff around. up to you.
- build the cutterhead cable with LC network and fusebox as described on vinylike.com or order a ready to go one. i am close to release a new RC network board with cutter current display which makes this step a lot more easy.
- you need a small adapterplate to fit the caruso. i update a drawing as soon as i find my notes. the VR mechanics has plenty of space to fit almost any cutterhead you can imagine.
- adjust everything and enjoy your cuts! finally there is nice and precise low end. people on the dancefloor are deeply grateful. your clients will start to ask what magic happened since the last cut.
in the end it will look something like this:<br>
Dubwise
Re: Caruso Head
Post: # 50758Unread post Dubwise
Thu Jul 05, 2018 3:59 am
Ok flo, when are the heads ready fi purchase.?
:?: :lol: 8) :shock: :shock:
SueDenim
Re: Caruso Head
Post: # 51308Unread post SueDenim
Fri Sep 14, 2018 4:59 am
Hi Flo - have you found your notes for the adapter plate yet?
As soon as know how to make one of these for my VR I'll put in an order for a Caruso :)
Thanks as always...
Dubwise
Re: Caruso Head
Post: # 51524Unread post Dubwise
Sun Oct 14, 2018 12:17 am
oh yess im still keen :shock:
Dubwise
Re: Caruso Head
Post: # 51544Unread post Dubwise
Tue Oct 16, 2018 2:44 am
Ok i don't think Flo is going to come through with the goods. So who else has is making quality feedback heads that will fit on a VR?
JHL
Re: Caruso Head
Post: # 51586Unread post JHL
Sat Oct 20, 2018 11:02 am
Dubwise wrote:Ok i don't think Flo is going to come through with the goods. So who else has is making quality feedback heads that will fit on a VR?
it seems myshank is in development
Dubwise
Re: Caruso Head
Post: # 51589Unread post Dubwise
Sun Oct 21, 2018 4:41 am
Thanks JHL, i'll keep an eye on My Shanks progress but these Lathe trolls are so elusive, no one answers emails, websites down, people disappearing. :lol: :lol: :lol:
Dubwise
Re: Caruso Head
Post: # 51590Unread post Dubwise
Sun Oct 21, 2018 4:46 am
I have Faith Flo will turn up again.
JHL
Re: Caruso Head
Post: # 51591Unread post JHL
Sun Oct 21, 2018 9:56 am
i think flo is super busy on other project,good things take time :D
and i think todd's Mantra head,james's sillitoe head is worth to focus as well
Dubwise
Re: Caruso Head
Post: # 51630Unread post Dubwise
Fri Oct 26, 2018 4:14 am
JHL wrote:i think flo is super busy on other project,good things take time :D
i will wait patiently.. :shock:
