lose pitch with VR
luke13
lose pitch with VR
Post: # 54869Unread post luke13
Thu Jan 30, 2020 1:47 pm
have a little problem when cut 12" records with Vinyl Recorder machine: at the beginning of cutting, about 1 cm of width the record lose pitch, then seems ok with good pitch.
I can try to reduce the weight of stylus but I don't know if is a good solution. The external motor that sell Souri can be a good solution? I don't check the technics motor but I change it about 1-1,5 year ago.
All solution can be appreciated.
With 10",8" and 7" I have no problems.
Thanks in advance for help
luke13
Re: lose pitch with VR
Post: # 54870Unread post luke13
Thu Jan 30, 2020 3:01 pm
okay, at the moment the external motor from Souri is not available...Any idea?
handcut
Post: # 54874Unread post handcut
Fri Jan 31, 2020 6:00 am
For the price of Souri's external motor and steel plate you can get a nice SP-15 or if you are patient an SP-10mk2. The SP-10mk2 is becoming very expensive on eBay, but sometimes you can still get a good deal. If you are good with electronics, the SP-15 can be a real bargain. A lot of them sell for parts because they have the famous speed problems, running backwards etc... but if you are capable of replacing all capacitors and installing a new chip from Fidelis Analog (much higher spec than the original) then you can have a solid, archive quality turntable for a sensible price with money left over for blanks and diamonds... Bon chance.
fredbissnette
Post: # 54878Unread post fredbissnette
Fri Jan 31, 2020 1:48 pm
i got an sp10mk2 out of a radio station for 50 bucks
they exist
HannesFTL
Post: # 55666Unread post HannesFTL
Sat May 09, 2020 7:49 am
- Little bit less weight
- Round extra lead in groove
- Don't monitor your cut (less weight innit)
You can get away with it, but tricky
