vacuum suction noise
nikc
Post: # 58861Unread post nikc
Thu Jun 24, 2021 10:57 am
Hello everyone!
I got a new pump recently, and got the swarf jar and tube really air tight. The suction noise near the stylus is loud now. Which is good as it picks up the swarf more easily now, as its powerful.
But I am hearing a slight noise on the record now, which could be other issues (need more heat etc which i have been increasing),.
But i wondred if its the suction noise on the record playback. Anyone know this to be an issue?
Nik
Nik Clifford
Pearl Home Records
Re: vacuum suction noise
Post: # 58885Unread post tragwag
Tue Jun 29, 2021 3:27 pm
yeah I've had this issue before, do you use a variac?
that's what I use to keep the suction only as high as I need it without getting audible in the cut or potentially crushing the tubing
nikc
Post: # 58888Unread post nikc
Wed Jun 30, 2021 12:42 am
Hello tragwag, thanks for replying.
No I am not using a variac, Its a vacuum pump by Vevor. It is 2 stage with 5cfm. It is powerful but was cheap so I am thinking it might not last long.
I made a new nozzle that doesn't bend at the end to get in place but curves round and has a more open opening. There is much less noise now and what a difference to the sound on the record. I am very happy with it.
Nik
Nik Clifford
Pearl Home Records
Post: # 58903Unread post tragwag
Fri Jul 02, 2021 8:33 am
awesome, glad to hear it got sorted. in general I'd really suggest a variac. I've run all of my vacuums over the years at 90 volts the highest (out of 120 usually)
Discomo
Post: # 58906Unread post Discomo
Fri Jul 02, 2021 10:07 am
Excellent suggestion.
I have a variac here which I use only for powering up old tube gear. Will use it on my suction soon as a voltage regulator.
The suction I have atm is from Souri, pretty good actually. It's a side blower and something else than what he was selling before.
Very quiet. But I still have a slight noise in my cuts, inaudible almost. After having given both speed&heat controller and EQ/iriaa (of the TR 560) a separate psu (which dramatically eliminated low noise),
and having decreased the space between suction-tube and stylus/blank to 1 mm (thank you PMST for many many suggestions and comforting support!) the only noise left is a windlike, midrange noise. Hope the variac will eliminate this as well.
(already have thrown out all unnecessary equipment, leaving me only with DAW >main unit (=speed/heat/eq regulator) > Amp > Cutter.
nikc
Post: # 58908Unread post nikc
Fri Jul 02, 2021 2:37 pm
Hi Thanks this is all Good information..I Will look up Variac and side blower.
Nik
Nik Clifford
Pearl Home Records
Post: # 58924Unread post tragwag
Tue Jul 06, 2021 1:43 pm
interesting! what level is this mid-oriented wind like noise coming in at dB wise?
Discomo
Post: # 59106Unread post Discomo
Mon Aug 09, 2021 5:26 pm
Totally missed this post
Can’t say exactly (don’t have the software to measure it)
But it’s gone now, since I use the variac. So your suggestion was truly excellent.
Finally found a good use for this bulky variac 😄👍🙏
karl hungus
Post: # 59110Unread post karl hungus
Tue Aug 10, 2021 3:26 am
Just for others with the same problem, I use a player piano vacuum that has a built in small variac. Its been working great so far. Similarly, I run it at about 75% of its max and that got rid of the whistling.
You can get them on ebay for about $300.
Post: # 59115Unread post tragwag
Tue Aug 10, 2021 11:07 am
awesome, glad it got sorted!
I use the same ebay player piano vac now with my own variac. it's really quiet and runs great, except when it's 78F+ in the studio and I have to do sides longer than 5min.
in that case I take the little rubber plug off the 2nd pipe and it stays cool enough not to overheat
