Alibaba for blanks??
Hey guys.. .Anyone tried Alibaba for their blanks?
Anything to avoid when cutting with a vinyl recorder?
I would presume a search of 'PVC plastics suppliers' may be fruitful, or am I wasting my time?
Any advice from anyone who's searched this path would be awesome!
- soeffingodly
Re: Alibaba
I've heard that PVC roasts diamonds really quickly. I'm pretty sure blanks are PETG plastic.
Re: Alibaba for blanks??
I can confirm that PETG is very good for Blanks. I get my sheets 4'X8' clear 2mm thick and then cut it myself 12"x12". I made a template made out of old Blanks stack on top of each other and use a router with bearing. But you have to make a hole first of 7.5mm with a good drill bit. Oh! I did show a Blank from Souri to the Plastic supply and they are the one that confirm that it's PETG.
- trailerparkjesus
were you able to get black PETG?
Interesting topic guys.
the black blanks from souri are special coated/sandwich layer. the middle part is black, the layers on both sides are transparent/clear.
you see the chip while cutting is clear
this material is not easy to source.
better buy blanks from myshank or souri
You're right andybee. It is impossible to get this kind of coated/sandwich plastic sheet in Canada or USA....it's seem that it's only available in Europe.
Unfortunately, Souri is not responding to my email since November 22, 2021 and I sent emails every week. I found that strange that after almost 13 years I have a Souri's machine and he's not returning my email. I'm buying a 100 blanks every 3 or 4 months. I will try to reach Myshank at this point.
