New lathes
organicmusic
New lathes
Post: # 59960Unread post organicmusic
Fri Dec 31, 2021 5:24 am
I have built three new lathes, different concept, fixed cutterhead and moving platter. Modified Technics SP-10 Mk3 to use with vacuum from underneath, Flokason Pitch18 and Maxon motor, high precision feed screw custom made in Germany, suspension box with depth coil to use with Neumann, Ortofon or Swiss made cutterheads, long Grace tonearm with Ortofon 2M black system. TMC air damped optical table.
Good news: Working excellent! Bad news: sold already...
leemichael
Re: New lathes
Post: # 59961Unread post leemichael
Sat Jan 01, 2022 6:55 am
Impressive, you sold all three?
Moving platter is interesting.
emorritt
Re: New lathes
Post: # 59962Unread post emorritt
Sat Jan 01, 2022 9:00 am
The moving platter is nothing new; lathes built for acoustic recording on wax (Lindstrom, Scully, etc.) had the platter moving under the recorder. This was because the horn or horns of varying sizes and shapes used for recording, couldn't move along with an overhead or sled assembly as with modern lathes. Easier to move the disc under the fixed recorder.
Not sure this will work, but if you get to the website, click the thumbnail for a larger image. If you look closely, there is a D spec recorder mounted on the machine for electric recording, but this photo features the setup as it would have been for mechanical (acoustic) recording.
https://www.americanbluesscene.com/american-epic-premieres-may-16-pbs/american-epic-machine/
organicmusic
Re: New lathes
Post: # 59964Unread post organicmusic
Sat Jan 01, 2022 4:33 pm
First step: 1:1 model made of wood and paper... second step: a lot of work!
Discomo
Re: New lathes
Post: # 59965Unread post Discomo
Sun Jan 02, 2022 3:00 am
Impressive and very beautiful! Keep posting pictures please!
organicmusic
Re: New lathes
Post: # 59968Unread post organicmusic
Sun Jan 02, 2022 1:48 pm
Suspension boxes... depth coil with carbon body, light and stiff. With oil damping pot and switch for heat.
organicmusic
Re: New lathes
Post: # 59969Unread post organicmusic
Sun Jan 02, 2022 2:07 pm
Some more pictures of the process. New center spindles made for the Technics sP-10 MK3 turntable with drilled hole for vacuum from underneath, depth coils (winding was no fun...)
emorritt
Re: New lathes
Post: # 59970Unread post emorritt
Sun Jan 02, 2022 4:16 pm
Yes, very well planned, meticulous and precision work!! I took metal shop in high school and was very interested in machining, but didn't pursue it. I do understand what painstaking work doing something like this would require. 8)
soeffingodly
Re: New lathes
Post: # 59973Unread post soeffingodly
Mon Jan 03, 2022 8:37 am
Well done!
urieldeveaud
Re: New lathes
Post: # 59974Unread post urieldeveaud
Mon Jan 03, 2022 9:31 am
this is awesome ! are you going to release this suspension box ?
what is the benefit of oil damping compared to air dashpot ?
thx, have a great day
uriel
gold
Re: New lathes
Post: # 60016Unread post gold
Sat Jan 08, 2022 2:15 pm
Beautiful work. Do you have any photos of your machine shop you’d like to share?
Re: New lathes
Post: # 60101Unread post Aussie0zborn
Thu Jan 27, 2022 4:26 am
Congratulations. Looks good.
MEGAMIKE
Re: New lathes
Post: # 60102Unread post MEGAMIKE
Thu Jan 27, 2022 6:55 am
great work
byronsyard
Re: New lathes
Post: # 60105Unread post byronsyard
Thu Jan 27, 2022 6:01 pm
awesome work sir very well done salute!
Rat
Re: New lathes
Post: # 60606Unread post Rat
Wed Apr 13, 2022 8:45 pm
Simply amazing ... a real credit to you
symatic
Re: New lathes
Post: # 60656Unread post symatic
Wed Apr 27, 2022 8:56 am
beautiful work!
farmersplow
Re: New lathes
Post: # 60665Unread post farmersplow
Thu Apr 28, 2022 12:30 am
A fantastic job! Very well thought out. Finely crafted. My respect! Congratulations on this work!
Thanks for the pictures and greetings from Austria
Thomas
Angus McCarthy
Re: New lathes
Post: # 60670Unread post Angus McCarthy
Thu Apr 28, 2022 4:11 pm
All I can do is join the rest in saying Bravo!
mjdoesvinyl
Re: New lathes
Post: # 60707Unread post mjdoesvinyl
Wed May 04, 2022 7:48 am
What a beautiful lathe!
mxlusky
Re: New lathes
Post: # 60867Unread post mxlusky
Fri May 27, 2022 4:54 am
Wow, this looks fantastic!
