New lathes
- organicmusic
New lathes
I have built three new lathes, different concept, fixed cutterhead and moving platter. Modified Technics SP-10 Mk3 to use with vacuum from underneath, Flokason Pitch18 and Maxon motor, high precision feed screw custom made in Germany, suspension box with depth coil to use with Neumann, Ortofon or Swiss made cutterheads, long Grace tonearm with Ortofon 2M black system. TMC air damped optical table.
Good news: Working excellent! Bad news: sold already...
- leemichael
Re: New lathes
Impressive, you sold all three?
Moving platter is interesting.
Re: New lathes
The moving platter is nothing new; lathes built for acoustic recording on wax (Lindstrom, Scully, etc.) had the platter moving under the recorder. This was because the horn or horns of varying sizes and shapes used for recording, couldn't move along with an overhead or sled assembly as with modern lathes. Easier to move the disc under the fixed recorder.
Not sure this will work, but if you get to the website, click the thumbnail for a larger image. If you look closely, there is a D spec recorder mounted on the machine for electric recording, but this photo features the setup as it would have been for mechanical (acoustic) recording.
https://www.americanbluesscene.com/american-epic-premieres-may-16-pbs/american-epic-machine/
- organicmusic
Re: New lathes
First step: 1:1 model made of wood and paper... second step: a lot of work!
Re: New lathes
Impressive and very beautiful! Keep posting pictures please!
- organicmusic
Re: New lathes
Suspension boxes... depth coil with carbon body, light and stiff. With oil damping pot and switch for heat.
- organicmusic
Re: New lathes
Some more pictures of the process. New center spindles made for the Technics sP-10 MK3 turntable with drilled hole for vacuum from underneath, depth coils (winding was no fun...)
Re: New lathes
Yes, very well planned, meticulous and precision work!! I took metal shop in high school and was very interested in machining, but didn't pursue it. I do understand what painstaking work doing something like this would require.
- soeffingodly
- urieldeveaud
Re: New lathes
this is awesome ! are you going to release this suspension box ?organicmusic wrote: ↑Sun Jan 02, 2022 1:48 pmSuspension boxes... depth coil with carbon body, light and stiff. With oil damping pot and switch for heat.
what is the benefit of oil damping compared to air dashpot ?
thx, have a great day
uriel
Re: New lathes
Beautiful work. Do you have any photos of your machine shop you’d like to share?
Re: New lathes
Congratulations. Looks good.
- byronsyard
Re: New lathes
awesome work sir very well done salute!
Re: New lathes
Simply amazing ... a real credit to you
- farmersplow
Re: New lathes
A fantastic job! Very well thought out. Finely crafted. My respect! Congratulations on this work!
Thanks for the pictures and greetings from Austria
Thomas
Thomas
- Angus McCarthy
Re: New lathes
All I can do is join the rest in saying Bravo!
