VR: Ground Loop with NJS NJA760
Sylvere
Post: # 61170Unread post Sylvere
Thu Jul 21, 2022 1:22 pm
hi trolls,
Anyboby experience buzz problem with the amplifier NJS NJA760 (provided by Souri) ?
Cause I ve got buzz running in my cutterhead. When I cut without amplifier it's ok no buzz just noise surface.
MainUnit, amplifier and mixer are plugged in my black lion audio pg 1F power regulator.
Any idea to fix the ground loop ?
thx a lot
syl
Re: ground loop with NJS NJA760
Post: # 61171Unread post markrob
Thu Jul 21, 2022 1:28 pm
If you unplug the line inputs and the buzz goes away, maybe consider 1:1 isolation input transformers.
Sylvere
Post: # 61172Unread post Sylvere
Thu Jul 21, 2022 2:52 pm
exactly when I unplug the line in buzz goes away !
thx for the tips
syl
Post: # 61174Unread post markrob
Thu Jul 21, 2022 9:52 pm
Make sure that your upstream audio path is not the cause before you go to the isolation transformer route. For example, if you are using a mixer, see if the buzz goes away if all inputs are disconnected. Is the buzz independent of the master level fader? If it moves with the fader, then the the cause is upstream someplace.
You can also try using a floating AC mains adaptor to float the safety ground on the power amp. If you lift this ground and the buzz goes away, then the transformer idea should work. I wouldn't use a floating safety ground as a final solution, just a means to see if the ground loop is broken after lifting the ground. If this stuff is in a common rack, you might have to isolate the chassis. To test this remove the amp from the rack.
Sylvere
Post: # 61175Unread post Sylvere
Fri Jul 22, 2022 3:20 am
Audio path is really clean, mixer is a Palmer monicon XL
-yes, I did but the buzz goes on...
I ordered an ART DTI 1:1 2 channels passives transformer
let u know
Sylvere
Post: # 61177Unread post Sylvere
Fri Jul 22, 2022 6:34 am
the buzz is only on the channel A !
B is cristal clear
Post: # 61180Unread post markrob
Fri Jul 22, 2022 10:02 am
If you swap the input connections, does the buzz move to channel B?
Sylvere
Post: # 61184Unread post Sylvere
Fri Jul 22, 2022 1:27 pm
No the buzz is still in A ch
I test with just with 2 SpeakOn and 1 input
the B ch is really clear with the 2 ch of cutterhead
but the input ch A is still running a small buzz
obviously when I cut the buzz is in L ch (A) :cry:
The output of Souri main unit is cristal clear.
Post: # 61185Unread post markrob
Fri Jul 22, 2022 1:56 pm
Seems odd that its only one channel. The would seem to go against it being a ground loop. Have you tried another amp? Are you running balanced or unbalanced connections?
Sylvere
Post: # 61187Unread post Sylvere
Sat Jul 23, 2022 3:38 am
Unbalanced connection only, cause the input of the amp is unbalanced.
I ve tryed with different cables (really short).
I will try with another amp as soon as I can !
and let u know.
Thanx a lot for your interest.
Syl
Sylvere
Post: # 61216Unread post Sylvere
Thu Jul 28, 2022 10:48 am
ART ATI transformer isolator 1:1 fix my problem :))
cheers
syl
Post: # 61217Unread post markrob
Thu Jul 28, 2022 3:11 pm
That's great to hear!
Tape27
Post: # 61545Unread post Tape27
Sun Oct 02, 2022 1:45 pm
hi,
my njs nja also causes some hum when I turn it on.
think it has nothing to do with the signal path as the hum is still there when line inputs are unplugged.
anyone has any suggestions ? maybe i can build some isolator before the powercable of the amp goes to the socket?
appreciate any input
peace
Post: # 61546Unread post markrob
Sun Oct 02, 2022 6:28 pm
Any light dimmers nearby? If you float the safety ground with the inputs unplugged does the buzz go away? If you have dirty AC mains power, perhaps a good line filter would help.
Tape27
Post: # 61548Unread post Tape27
Mon Oct 03, 2022 8:31 am
hey,
thanks for the fast answer,
no dimmers nearby
can you explain what you mean with floating the safety ground?
thank you!
peace
Post: # 61559Unread post markrob
Mon Oct 03, 2022 11:01 pm
In the states, its the green wire ground. This is the single round contact, not the two flat ones. There are adaptors that allow you to lift this ground. They are designed for older two prong AC outlets. Not sure the equivalent exists outside of the US. This is not a long term safe thing to do. It is just to help identify the problem.
