Mackie Big knob
David34
Mackie Big knob
Post: # 61652Unread post David34
Mon Oct 24, 2022 5:12 am
Hello!!
At the advice of some experts on here, I have purchased the Mackie big knob version 1.. to replace the Souri maxed out mixer.. And improve the sound quality..
Is there anything I should be aware of? (routing etc) I am aware that I need to convert RCA into 1/4" Jack, is there any sound quality issues with this? Why did Souri not use 1/4" or XLR? Are RCA cables ok?
If anyone is willing to share a routing guide for me, you will get good karma and save me hours of hair pulling..
I really appreciate any help!
Govinyl
Re: Mackie Big knob
Post: # 61653Unread post Govinyl
Mon Oct 24, 2022 5:33 am
Interesting! I would like to know more about this as well. I also own a Mackie Big knob and am about to change the original mixer.
PMST
Re: Mackie Big knob
Post: # 61654Unread post PMST
Mon Oct 24, 2022 5:49 am
In terms of routing and using a Big Knob, mine is like this
Cutting:
Audio Player
Big Knob
Cutter Amp
Playback:
SP10 MKII
Preamp
Level Meter
Monitoring
I do all my own iRIAA in the box, wanting the cleanest possible signal path for the cutting chain
Sylvere
Re: Mackie Big knob
Post: # 61655Unread post Sylvere
Mon Oct 24, 2022 6:26 am
a really good alternative is the monicon XL from Palmer !
really versatile routing.
Re: Mackie Big knob
Post: # 61656Unread post tragwag
Mon Oct 24, 2022 1:59 pm
Cutting:
Audio Player
Big Knob
Cutter Amp
Playback:
SP10 MKII
Preamp
Level Meter
Monitoring
mine is the same pretty much, with level meter between big knob and amp on the cutting chain.
the big difference is not monitoring while cutting, but in my experience I haven't missed it
David34
Re: Mackie Big knob
Post: # 61657Unread post David34
Mon Oct 24, 2022 4:53 pm
thanks!
Sylvere
Re: Mackie Big knob
Post: # 61659Unread post Sylvere
Tue Oct 25, 2022 4:46 am
on my side I think that is better to avoid to transit modulation by the meter and go directly to amp !
just feed the meter by another output of a splitter is reliable.
But in my set up I use RIAA from Souri main unit without problem.
David34
Re: Mackie Big knob
Post: # 61683Unread post David34
Mon Oct 31, 2022 7:36 pm
Any chance someone can supply a routing video or detailed guide for an idiot (me!)
I struggled setting this up to start with when received from Souri..
So happy to rid of that mixer, but it’s so confusing the way it’s all routed…
I really appreciate it..
David34
Re: Mackie Big knob
Post: # 61691Unread post David34
Thu Nov 03, 2022 4:21 am
We have it all routed, and it s cutting good vinyl, but we are missing some of the elements, like balance control etc..
If anyone has a routing guide for VR, I will be eternally grateful!!
PMST
Re: Mackie Big knob
Post: # 61696Unread post PMST
Fri Nov 04, 2022 9:33 am
Balance is adjustable by the cutter amp volume, that is all it is doing, sending less signal to one of the sides as you turn the knob. What else is missing?
Sylvere
Re: Mackie Big knob
Post: # 61701Unread post Sylvere
Sun Nov 06, 2022 12:33 pm
Cinch RCA is not a problem !
First improvement u can do for your system: buy a black lion Audio PG1 !
David34
Re: Mackie Big knob
Post: # 61703Unread post David34
Tue Nov 08, 2022 4:36 am
Got a Furmann one... they are great!
