Technics sp10 mkII tonearm?
Hi. Some time ago I bought a Technics SP 10 turntable to use in my Vinyl Recorder system. I have the turntable, the power supply, I have had it serviced and now it's turn to buy a tonearm for it...
Any suggestions? I don't want to spend a fortune on it, I'm just cutting for a hobby (10 years so far) and I'd like it to have a detachable headshell so I could use an Ortofon Concorde type stylus on it. Made the mistake of buying a Technics sl 1200 tonearm but its shape makes it impossible to adapt to the sp10. I used to have an SME 3900 but I hated it and sold it long ago.
Any of you can help?
- Oslovinylfreseri
Re: Technics sp10 mkII tonearm?
Hey! Congratulations with a fantastic record player. There are written a bunch of tips about what suits best online, but for my sp-15 I used a rega tone arm. I think it was a RB-250. They are easy to mount and sound pretty ok considering the price you can get one for second hand (or new). At least it’s a good start if anything.
Good luck!
Good luck!
Likewise, i'm using a Rega 250, easy to install and reasonably priced for what it is
Thanks for your answers!
Anyone tried a Jelco tonearm?
- mjdoesvinyl
I saw an Eizz Tonearm for under 1,000 if you want a 12" one. Check out Schick as well if you want a SME type ARM.
Isn't this tonearm used only for monitoring to check if there are skips on the record? If so, why do you guys buy an expensive tonearms?
I use it a lot for exact heating and some realtime de-essing too
And like PMST said you really want it for calibration: volumes, eq curve even if your using the main unit as audio path
I bought a beaten Rega Planar. Usually better price than arm only and got a great deal with fresh needle.
Asked a woodworker friend to cut the arm part of, glued a piece of wood to bottom and presto.
Hope this helps!
Hope this helps!
That's exactly what I was thinking lately! Probably the best/cheapest option.
- leemichael
SME 3009 Tonearm is commonly paired with the SP10.
