Landsurfing and embossing
kafkablues
Post: # 62244Unread post kafkablues
Wed Feb 01, 2023 12:43 pm
Hi Folks,
I am currently embossing and getting some very good results. The only issue I am getting is 'landsurfing' nearly always at the start of the disk. Is this a given with embossing or is there anything I can to do to reduce it happening?
Much appreciated. :)
apoklis
Re: Landsurfing and embossing
Post: # 62249Unread post apoklis
Wed Feb 01, 2023 9:27 pm
What is the width of the starting grooves ? Is it the same as the end grooves? Is the lathe level all the way across?
apoklis
Post: # 62250Unread post apoklis
Wed Feb 01, 2023 9:48 pm
Also ,I ve had problems when the sylist is leaned too far back. check you angle and weight . see if that helps.
piaptk
Post: # 62253Unread post piaptk
Thu Feb 02, 2023 2:50 am
What do you mean by “landsurfing” exactly? Playback stylus skating? Or riding between horns on the side of the groove? What embossing styli are you using?
kafkablues
Post: # 62280Unread post kafkablues
Sun Feb 05, 2023 3:26 pm
Hi folks,
Many thanks for the advice. Think I’m nearly there. I’m just stuck between ‘tricky’ tracking with very low noise and ‘no problem’ tracking with a little noise (it’s acceptable but I want to get it better).
I guess it might be a trade off. Will experiment a little more this week.
Piapkt: I’m using your needle and yes I’m talking about the horns.
Post: # 62307Unread post tragwag
Wed Feb 08, 2023 2:31 pm
yeah I hear you there! it's an angle adjustment usually for me.
Like you I'll get the lowest surface noise, and some "horn riding" issues on louder cuts.
Then I angle the head back towards flat, and get better tracking, but slightly higher surface noise.
