Printable Label Stock
Dub Studio
Post: # 62347Unread post Dub Studio
Mon Feb 13, 2023 10:33 am
I knocked some up label designs a while back and the company that made the tooling have published my designs for other people to use. I have no affliliation with them, but I do recommend them as they always do a good job with fast turnaround. They have a load of different paper stock too... my personal favourites are the "removable" stock, because they peel off nice and easy if you misalign them.
For some reason they are listed as CD labels, but here are the codes, descriptions and links:
Ref: FXCDR6 - these ones have 4 x 100mm center labels, and 2 x sleeve labels (50mm height x 75mm width). The sheet is reversible so you can print one set at a time and then turn them around and do another using the same template: https://www.flexilabels.co.uk/product/6-custom-labels-per-a4-sheet
Ref: FZCDS6 - these ones have 4 x 85mm center labels with large holes, and 2 x sleeve labels (40mm height x 60mm width). These are not reversible: https://www.flexilabels.co.uk/product/6-custom-shaped-labels-per-a4-sheet-85-mm-diameter
Ref: FZCDR6 - These are the same as above but small hole: https://www.flexilabels.co.uk/product/6-custom-labels-per-a4-sheet-85-mm-7-mm-diameter
They all come with downloadable templates, but I have never used them since I already had my own. Enjoy!
SueDenim
Re: Printable Label Stock
Post: # 62348Unread post SueDenim
Mon Feb 13, 2023 10:47 am
Nice one Henry! Cheers for sharing...
Hope you're doing good mate.
raretone
Post: # 62376Unread post raretone
Thu Feb 16, 2023 3:04 am
Thanks for sharing, I've just received some blank lables from the same company.
What printer are you using to print onto these? Or are you getting Flexilabels to print onto them for you?
I'm looking into a new printer to print my own labels (very small runs only at the minute) so any reccomendations are very helpful!
boryo
Post: # 62446Unread post boryo
Sun Feb 26, 2023 3:25 pm
I'm using Canon PIXMA G640 to print mine. Its photo printer and I print on photo paper and the quality is amazing. I'm going to buy bigger printer so if you are interested we can work out something...
msartori
Post: # 62449Unread post msartori
Sun Feb 26, 2023 5:22 pm
UK DELIVERED ONLY?
msartori
Post: # 62655Unread post msartori
Mon Mar 27, 2023 12:59 pm
Does anyone have the pdf template of the first link?
Post: # 62669Unread post piaptk
Thu Mar 30, 2023 2:18 am
