Anti slip serrations on 7" records
martinstamper
Post: # 55616Unread post martinstamper
Mon May 04, 2020 4:03 am
HI
I was wondering if anyone had any photos or more info on the molds that would have had gripper ridges on them. (The bumps around the outside of labels on 45s to stop them slipping on stackable record players)
Purely curious as I've never seen any stock footage or anything on them.
Re: Anti slip serrations on 7" records
Post: # 55636Unread post Aussie0zborn
Thu May 07, 2020 9:08 am
The "anti-slip ring" (or the so-called 'necklace') on 7" records during the heyday of record stackers was created by the stamper forming tool These ridges are therefore not on the record pressing mould - just the stampers. Once their used was phased out, you will see a raised ring around the outer part of the label. The ridges in the stamper would sit on this raised ring.
martinstamper
Post: # 55665Unread post martinstamper
Sat May 09, 2020 7:22 am
Aha! Very interesting! What stopped the ridges flattening out (or at least losing their definition) on the press?
Also wouldn't the cavity under the ridges cause pressing issues with an accumulation of dust?
Are there any pictures out there?
mich
Post: # 68577Unread post mich
Sun Dec 21, 2025 4:00 pm
Anyone has this tool available for sale or at least share some pics?, thanks!!!
Post: # 68678Unread post mossboss
Tue Jan 06, 2026 9:24 pm
Ridges on Stampers
Quite easy, fill the back of the stamper with soft solder A bit of emery cloth to get the roughness out finer cloth to finish of Done about 10 minutes from memory
There was pressing tool as well but we rarely used it That was to actually press the ridges in the stamper,
We used a heated tool to press them into the lacquer than of course got them on the metal work....
"The Vinyl Truth"
mich
Post: # 68735Unread post mich
Tue Jan 13, 2026 5:02 am
Thanks Chris, the Polygram ones looks more a heated tool on the lacquer, I'm curious to see the tool or getting one instead of building it, which won't be hard anyway.
klikli_ska
Post: # 68803Unread post klikli_ska
Thu Jan 22, 2026 4:54 am
Very interesting post!
Always curious about how it's made and if there's any selling tool that could make it. A little bit related, still looking for any manufacturer that could provide us with a die/punch for making the "4-prong" center hole which also appear on the attached picture. Any suggestion?
Thanks in advance!
Take care my family!
boryo
Post: # 68883Unread post boryo
Mon Jan 26, 2026 3:42 am
from a DJ perspective this is the thing i hate the most on older 7". from now on when i order 7" i will explicitly ask to have them without anti-slip ring (just in case) :)
Post: # 69077Unread post mossboss
Mon Feb 09, 2026 5:33 am
Thanks in advance!
The post's here clearly state how it was made, either on the lacquer or on the finished stamper In so far as the punch out center is concerned, This was called the Mercury center, memory is not goof enough to remember why, Ha I thought it was only three! One used a "spider" insert if the center was punched out so they can be played on a standard 9/32" spindle or used a solid or hollow 1 1/4" round insert to fill the hole
Any way we can certainly make a tool that will do it either pneumatic, hydraulic, or a simple kick press for either serrations or punching out the Mercury center
cheers
"The Vinyl Truth"
klikli_ska
Post: # 69091Unread post klikli_ska
Wed Feb 11, 2026 6:37 am
PM'd, Chris!
Post: # 69161Unread post mossboss
Fri Feb 20, 2026 4:57 pm
Yes seen that I don't get here much
Been very busy the last year or so Far to much on hand but thats what it is, may be ill come more often once things settle down, wishful thinking of course, Ha
"The Vinyl Truth"
