Hi guys! I'm trying to figure out approx the average price when I have learn (will cost more in the beginning hehe).
If I use a Diamond Stylus from Vinylium and mainly cut "pop/rock" that do not have insane bass and buy "vinyl like records" not acetate.
Where would I end up in price approx ?
Say I cut 4 minutes 2 sides seven inches?!
Need to see how much I need to charge for the work + material.
I understand it is impossible to give an 100% answer but at least if I know how long the Diamond stylus use to last I can do some calculating on my own.
Thanks
- Vinlyomaniac
Vynil man
Ok Here we go
How long is a piece of string? that long or a little longer or shorter
OK
Jokes aside An average Saphire stylus will provide around 20 Hours of cutting life
Now I have had them last around 60 hours or as little as 1/2 hour
There is a post here from someone that confirmed over 200 hours
As a rule you change when you have to assuming that you do not ruin it by yourself
It is a case of the grain in the stone from where it has been cut so sometimes you get a stylus that defies the rules at both ends of the scale
Having said all of that I would have thought that as an average for a diamond you would have to allow around the 100 hours as an average life span over a period of time if course
In other words say over 10 styli
OK
"The Vinyl Truth"
