smoke effect vinyl pressing
Milkmustache
Post: # 65602Unread post Milkmustache
Tue Aug 27, 2024 2:34 am
Hi there,
I'm trying to press trasparent base with red smoke on it. (attached for reference, pic1 is the effect display, pic2 is what I pressed)
As you can see, the smoke effect I pressed is no good, the red color swallow the most part of transparent. I use solid red mixed with transparent, and have tried diffrent blend ratio, but the effects are no good.
Is there something about the solid color's melting point?
The next I'll try to mix transparent and red, make sausage, and wrap the sausage, put some transparent granules into it. I'll post them later.
Thanks
misjah
Re: smoke effect vinyl pressing
Post: # 65603Unread post misjah
Tue Aug 27, 2024 2:40 am
i'd say you're almost there. probably bigger patches of solid red in the mix will do the trick.
Milkmustache
Post: # 65604Unread post Milkmustache
Tue Aug 27, 2024 2:54 am
It sounds right, but the granules gauge are the same, and they will mixed in extruder's screw, so it's really hard to make bigger patches. How did you mix the granules? Thanks!
