So these where laying on the outside, which was included in a deal. Would you try to restore these or does anyone know any good fitting new containers instead ?
I feel that if I save them I will end up having them on a shelf for 5 years until I get time to fix them, but on the other side I love to keep original parts.
What would you do ?
Restore or replace ? Galv containers
Re: Restore or replace ? Galv containers
the pics...
- Aussie0zborn
Replace. If they are lined with vulcanized rubber, you would have to strip it and have the rubber replaced, This should only cost about $5,000. You can make new ones from PVC for less and upgrade to a diagonal design for better quality.
What are you planning to do with this gear?
