selfbuild delta press
alex rex
Post: # 49509Unread post alex rex
Fri Mar 02, 2018 5:33 am
hi guys,
i've build my own delta press (in scale 1/24.) :D
i designed a paper model assembly kit to build your own litte pressing plant.
the card of the paper model is included with orders in few pressing plants in germany.
by a total of 6 issues you will have your own little scale-model pressing plant.
i just wanted to share this with you guys. hope you like it ..
i'm the artdirector of a small underground magazin called vinyl leaks, this paper model kit is a small 6 issue series of the magazin.
the magazin vinyl leaks focus on the passion behind the production of records, by keeping an eye on education, oddity, fun and curiousity.
for more information and pictures, check out: vinylleaks.alexrex.de
issue #1 delta press and extruder unit
(more is coming soon)
Gridlock
Re: selfbuild delta press
Post: # 49517Unread post Gridlock
Fri Mar 02, 2018 4:43 pm
We're reaching levels of dorkiness that are theoretically impossible. Took the day off work to put mine together. The wife says she wishes it was like a "Polly pocket" but she also calls my lathe "the long shank". I was like, yes I have 2 long shank styli. One ruby and one sapphire, so, what are you talking about? She said yeah! The LONG SHANK. THE ONE YOU USE TO CUT RECORDS. THE BIG MACHINE WITH THE LAMP. THE FWCKING LONG SHANK. and so forth. I'm still giving her the -20db treatment to this very day
andybee
Post: # 49601Unread post andybee
Thu Mar 08, 2018 3:25 am
Hello Alex!
This is absolutly amazing!!!!!
I always want to print out a mini-toolex with 3-d printer, but
never had the time...
This is much better, because it looks fantastic!
I did not understand, how I can get this freaky shit,
but I will find out ;)
Very very well done too!
Can´t close my mouth and eyes ;)
Keep on rockin!
Andi of my45
