Weight of stamper
leethal
Weight of stamper
Post: # 52004Unread post leethal
Thu Jan 03, 2019 8:40 am
Hey guys just a quick question. What is the typical weight of a 7" (10" to be accurate) stamper when it comes off the laquer?
leethal
Re: Weight of stamper
Post: # 52041Unread post leethal
Mon Jan 07, 2019 9:30 am
Bump
leethal
Post: # 52217Unread post leethal
Sun Jan 27, 2019 6:38 pm
Anyone at all. Dont be shy now.
Post: # 52218Unread post Aussie0zborn
Sun Jan 27, 2019 10:55 pm
EMI Greece 12" stamper specification...
184.2 ~ 198.4 grams
A lighter stamper will give you a faster cycle time but if the nickel is stressed and not ductile it will fail sooner than a heavier stamper will fail. Failiure = the outside edge of the stamper cracks along the gate of the mould.
leethal
Post: # 52280Unread post leethal
Fri Feb 01, 2019 5:48 am
Cheers man. So does this translate to 152gm - 164gm for a 10" laquer?
Post: # 52281Unread post Aussie0zborn
Fri Feb 01, 2019 6:17 am
I haven't calculated it but it seems you have. That would be a good starting point and might be right on the mark.
