New Plating Development - GrooveCoated Stampers
gottagroovematt
Post: # 52870Unread post gottagroovematt
Wed Apr 10, 2019 9:11 am
I thought some folks here might be interested in this new type of stamper we are using at Gotta Groove -- they are called GrooveCoated stampers, and we are really excited about them. In an admittedly oversimplified description of it, we use a special coating on the face of the stamper which strengthens and extends the stamper life. In most cases, twice the number of records ordinarily produced from a single set of stampers can be made from GrooveCoated stampers.
You can read in more detail about them here:
https://www.gottagrooverecords.com/process/groovecoated-stampers/
We would be very interested on feedback from the community on the records we produce from these stampers, so please feel free to reach out to us.
Matt Earley
Gotta Groove Records
(800) 295-0171
emorritt
Re: New Plating Development - GrooveCoated Stampers
Post: # 52873Unread post emorritt
Wed Apr 10, 2019 3:25 pm
Chrome? That was the final step for 78 stampers made by RCA Victor in the 1940s, in order to make them last longer. Or, as Milton Cross put it, "it receives another coat, this time of hard, gleaming chromium" 8)
Post: # 52905Unread post Aussie0zborn
Fri Apr 12, 2019 6:10 am
We were chrome plating the B side stamper in 1991. Easier release and allows the pressing to always come out on the top mould when using semi auto presses. But just a quick flash plating of chrome, otherwise you are masking the audio.
emorritt
Post: # 52907Unread post emorritt
Fri Apr 12, 2019 8:20 am
Yes, Leopold Stokowski also accused Victor's processing department of "buffing the highs off the record" as well.
Post: # 52921Unread post Aussie0zborn
Sat Apr 13, 2019 9:27 am
That means they were polishing the crap out of the mothers. Polishing mothers helps if you have a "horn" problem. Stampers made from polished mothers also allow easier release of the pressing from the stamper. The polishing process does affect the high frequencies if done too vigorously.
It's up to the cutting guys and gals to make clean cuts with minimal horns.
