Quality Checking Turntable
trendkiller
Post: # 55090Unread post trendkiller
Tue Feb 18, 2020 12:25 pm
Hello,
Does anyone know anything about the turntables in this video? The stopped upon detecting a crackle? Do these still exist?
https://youtu.be/6d4wBCADxZo?t=199
Thanks.
martinstamper
Re: Quality Checking Turntable
Post: # 55114Unread post martinstamper
Fri Feb 21, 2020 1:46 am
Not sure about those ones but this might be of interest. And I think one came up for sale on German ebay a while ago. "Automatic Tick Registration Machine" by Polygram
trendkiller
Post: # 55119Unread post trendkiller
Fri Feb 21, 2020 3:46 pm
That does look interesting, thank you. I can't seem to find anything about them though.
Post: # 55130Unread post Aussie0zborn
Mon Feb 24, 2020 8:53 am
This turntable is primarily designed for playing mothers. It plays the record backwards and stops when a "tick" is detected. The operator can then play the record from that point on in the normal direction and examine the tick without searching.
The reason the record is played backwards is that a tick always sounds like a tick whether it's played backwards or forwards. It can't ever be part of the music. If the record played in the normal direction, a snare drum would activate the stop circuit. When played backwards, the snare drum and its reverb tail no longer present a short sharp sound.
I saw a lot of these At EMI New Zealand. They hadn't been used for years because "they don't really work" I was invited to take them with gear I bought but decided against it.
llary
Post: # 55153Unread post llary
Tue Feb 25, 2020 8:05 pm
I'm not sure if you are interested in these as a curiosity or to do actual quality control. Software is a better way to do quality control these days, you can record at high speed and there is commercially available click/pop detection software.
phax
Post: # 55157Unread post phax
Wed Feb 26, 2020 10:19 am
we have it for sale!
have a look here: https://www.lathetrolls.com/viewtopic.php?f=4&t=7941&p=52064&hilit=atrem#p52064
trendkiller
Post: # 55161Unread post trendkiller
Wed Feb 26, 2020 12:13 pm
Ah, that makes sense. Good ol' EMI...
trendkiller
Post: # 55162Unread post trendkiller
Wed Feb 26, 2020 12:18 pm
Thanks. Mostly, I was curious; I hadn't seen these before and thought it was cool. The thought of comparing one to software piqued my interest.
frechdachs
Post: # 59561Unread post frechdachs
Wed Oct 06, 2021 4:13 am
Could you tell me about such a software? I'm looking for an automatic digital solution to detect and record pops and clicks.
Also, does anyone know whats the best needle to play mothers?
