FS: Complete Finebilt Record Press Setup
llary
Post: # 59609Unread post llary
Tue Oct 12, 2021 12:09 am
We have a very nice Finebilt for sale currently based in Taiwan.
Currently set up for 220V 60hz but motors can easily be swapped out.
1950s Finebilt 150 ton press, fully refurbished with new hydraulic pump and tank with oil chiller.
1950s Aragon vertical extruder, barrel completely stripped cleaned and rebuilt, brand new Wattlow heater bands and low noise blowers, 7" touchscreen, Delta VFD (screw speed adjustable 1-60rpm) and networked PLC.
Mobineko trimmer with adjustable platter speed, knife temperature and timers controlled through LCD display. Safety light curtain can also control full auto mode.
Includes Mobineko press controller and software that allows all functions to be controlled through a touchscreen. Get perfect records every time as the system uses mould temperature control instead of fixed timers.
Some pictures show traditional Chinese on the HMI interface, our system is multilingual with English built-in and you can add your own translations with QT Linguist.
Cycle time around 40-50s per 180g 12".
Includes 12" (lightly used) and 7" (brand new) book moulds profiled to Viryl dimensions. We can assist with profiling to other mould specs if required.
Turnkey pressing setup for a micro plant, just needs a small water chiller and electric or gas steam boiler.
Asking US$70k for the press, extruder and trimmer or we are happy to sell as separate parts. More photos and videos available, PM for more info.
llary
Re: FS: Complete Finebilt Record Press Setup
Post: # 59686Unread post llary
Sun Oct 31, 2021 11:14 pm
Press has been reserved pending final sale, thanks!
