Plating problems
Willcutter
Plating problems
Post: # 59995Unread post Willcutter
Thu Jan 06, 2022 7:18 am
Hello,
Anyone else with this problem?
Apparently the silver is not fixing correctly, and during the flash process the thin layer of nickel before the lead in comes off the lacquer.
The problem is the same using Transco Lacquers.
Willcutter
Re: Plating problems
Post: # 60002Unread post Aussie0zborn
Fri Jan 07, 2022 6:22 am
It's called "Crow's Feet". Contamination in the bath solution is giving you stress. It usually appears in the run-out groove. It is not thought to be related to silvering. What happens when you plate a nickel matrice in the same bath?
Yasiek
Post: # 60004Unread post Yasiek
Fri Jan 07, 2022 7:04 am
24h filtering through carbon filters + dummy on low amp (3-5A)should help. Do not forget to supplement the surfactant afterwards.
Baths in which you process laqs should be filtered through carbon filters on a monthly basis, obviously depends on the amount of work.
We have noticed that nickel deposits (anodes, and not the electrolyte) are too warm (right after the process), this effect also occurs. in general, anything that increases stress in the baths can cause it.
Willcutter
Post: # 60032Unread post Willcutter
Wed Jan 12, 2022 7:55 am
Chemical treatment is in process. We don't use to put nickel matrice using this bath. We use it only for flash.
Willcutter
Willcutter
Post: # 60033Unread post Willcutter
Wed Jan 12, 2022 8:05 am
could you tell me more about carbon filters?
We use filter aid + coal all the time.
Willcutter
