donkd
Vinyl from Loud Digital Masters: Restoration Options & Cutting Engineer Perspectives?
Post: # 69458Unread post donkd
Sun Apr 19, 2026 4:40 am
Hi!
I am a mastering / mixing engineer and am currently commissioned to prepare audio delivery of licensed re-releases.
For some older releases there are no vinyl masterings available and there is no way to get a separate master from the original mix. So the files i am working with are 16 bit / 44.1 kHz usually very loud (ca. -6 to -5 LUFS) and have low dynamic range (around 1.5 LU). From what i know, pressing this onto vinyl would be a very bad idea.
Now i am wondering if there is a way of restoring or reintroducing dynamics with restoration tools, dynamic expansion and so on or in general a workflow of handling this. I read some reports in forums, but would love some professional advice.
My questions are if anyone has any experience with this or if it is a lost cause?
And from a lacquer cutting perspective, how do you handle cases where the mastering you get is actually not suited for vinyl?
Thanks
Phinster
Re: Vinyl from Loud Digital Masters: Restoration Options & Cutting Engineer Perspectives?
Post: # 69459Unread post Phinster
Sun Apr 19, 2026 5:16 am
If the files look like rectangular boxes on your DAW, try lowering the digital output..if this just results in smaller rectangular boxes then you'll have to make do
Occasionally you will see the peaks and valleys of the waveform return depending on how the original was boosted. I can't remember the mechanism involved
however...this is all too common an effect unfortunately..good luck and have fun!
Greg Reierson
Post: # 69460Unread post Greg Reierson
Sun Apr 19, 2026 11:52 am
What you describe is the norm, not the exception. For some real world context, 90% of the titles I cut these days are not mastered specifically for vinyl. And that's true for everyone from Harry Styles to the Foo Fighters to any hip hop / rap album that comes in. Part of the art of cutting in the modern era is learning how to make that stuff work in a groove.
If you are they one supplying master files for cutting, the best you can do is drop the level about 10 dB (that's the first thing I do with any incoming master), minimize HF distortion and sibilance and hope a good cutting engineer is on the other end of the equation.
Greg Reierson
VMS70 :: SAL74B :: SX74
donkd
Post: # 69463Unread post donkd
Mon Apr 20, 2026 3:31 pm
Thanks for your responses, that already helps a lot
mushroomjesus
Post: # 69473Unread post mushroomjesus
Wed Apr 22, 2026 1:28 pm
It’s also very program-dependent. A -6 LUFS drum & bass track is going to behave very differently than a classic rock mix with wide stereo mic techniques that’s been pushed into modern streaming limits.
So yes — this is the norm now — but the real question isn’t “can it be restored,” it’s how far you can actually push that specific material through the cutter head. That determines everything.
Dense, limited electronic material carries constant energy and heat
Wide stereo acoustic material can create lateral/vertical issues when folded into a groove
Because of that, cut level ends up being dictated by the program, not the target. You’re always balancing groove velocity, HF stress, and tracking safety.
A lot of modern music was never designed with disc cutting in mind. Even genres that are “vinyl-heavy” are often delivered as streaming-optimized masters that aren’t directly suitable.
That said, it’s not a lost cause. As mixing and mastering engineers, it’s our job to guide artists toward material that translates properly. In many cases, that means adjusting or reworking the master — not just accepting the streaming version as-is — so it can actually exist as a playable, musical record.
Most of the time, we’re working within those constraints, but there’s still a path to getting a good cut if the material is handled correctly upstream.
And just as importantly, it’s our job to manage client expectations — helping them understand how loud a record can realistically be cut, how much high-frequency content can be reproduced, and what trade-offs are required to get a stable, musical result on disc.
Greg Reierson
Post: # 69474Unread post Greg Reierson
Wed Apr 22, 2026 1:57 pm
Truth
Modern recordings are way beyond what was anticipated when the vinyl format was conceived. A 50+ year old lathe doesn't know what a digital limiter is. It doesn't understand -6RMS. It doesn't understand 808s or hard panned electronica or noise records or ultra-distored hip hop. All of these things need to be controlled to work in a groove. Cutting records in 2026 is action packed, I can tell you that...
Greg Reierson
