Sound maximizer
- Audiofiligram
Sound maximizer
Hi Trolls ,
I was thinking about using a Sound maximizer Plug in From Universal Audio
to get more Loudness on Tracks , this tool give you the possibility to get
higher perceived loudness without influencing Dynamic Range of the Audio Material . The Plug ins adds harmonics to the original Signal , Specially
for high Frequencies it could be a Problem ? What do you think about it ?
Has somebody some experience ?
I´m using The VC 2000 Amp & SC 99 Cutterhead .
Thanx
Thanx
Got to watch out when exciting the high end frequencies. That is how cutterheads get smoked. Most cutterheads have their resonant frequency in the high end... And, they do tend to naturally emphasize the high end.
A lot of people do banded compression and maximization. I would just be careful about the higher frequency bands.
You can also use stereo expansion to get more perceived volume.
- Audiofiligram
- dietrich10
in my cutting chain i use 6 primary plugins..
I use a desser
then an EQ (which is set up with my tones)
RIAA
Another EQ I use to control my sound
high pass at 30hz lowpass at 10K
and a limiter to catch any overly loud hits
thats what goes to the cutter
now in my mastering chain for when i write/mix music
Desser
EQ
Final master
Limiter
I use a desser
RIAA
Desser
EQ
Final master
Limiter
- Audiofiligram
I use both frequency analysis and spectral analysis to insure that the energy is in the frequency ranges I want.
- dietrich10
Duh... My ears are always the judge and jury. Naturally.
- Angus McCarthy
Probably not between. You want to keep that connection as clean as possible, you know. Somebody mentioned elsewhere on here about using the monitor output to drive a Spectrometer.Audiofiligram wrote:Thanks for The Input Trolls ...
Certainly the best thing to do would be to plug a Spectrometer between
amps an Cutterhead to control The Frquencies ....
- dietrich10
visual inspection != final determination
just one of many things I use to make good cuts...
i am a musician at heart though. so, my ear is what i rely on no matter what.
- Audiofiligram
I got the possibility to get the signal from the Cutterhead calledAngus McCarthy wrote:Probably not between. You want to keep that connection as clean as possible, you know. Somebody mentioned elsewhere on here about using the monitor output to drive a Spectrometer.Audiofiligram wrote:Thanks for The Input Trolls ...
Feedback Output (There is an output on teh Amp)
- Audiofiligram
SpectraFoo
1K is the resonant frequency of the SX74. With the SAL rack's RIAA pre-emphasis that starts at 1K and goes up as the freqeuncy increases. Yes, really. The highs get excited by this system. A number of older mono cutterheads had a resonant frequency that was higher than 1K. Read your AES anthology.
- leo gonzalez
opcode66 wrote:1K is the resonant frequency of the SX74. With the SAL rack's RIAA pre-emphasis that starts at 1K and goes up as the freqeuncy increases. Yes, really. The highs get excited by this system. A number of older mono cutterheads had a resonant frequency that was higher than 1K. Read your AES anthology.
I get excited when i read your posts, but not exactly in a positive way.
there was no reason to bring "resonant frequencies" into this topic. but of course you had to because you seem to love mixing up things all the time.
You are mixing up resonant freqs with the riaa in a very funny way which could be very misleading.
please stop posting like this.
