BSB 74 Calibration
jjgolden
BSB 74 Calibration
Post: # 20008Unread post jjgolden
Wed Jun 06, 2012 8:57 pm
Hello,
Does anybody have documentation or working knowledge of how to
calibrate the left and right BSB -74 modules?
I'm assuming you need to power and calibrate them while removed from the chassis...?
I need to get my L&R thresholds equal.
The BSB left channel shows about 10db of gain reduction before the right kicks in. Also the gain drops about 1.5db between "bypass" and "ON"
Description of what the "P" trim pots are would be great.
(i.e. where's the threshold and where's the gain's?)
Step by step instructions with nice color photos would be invaluable! javascript:emoticon(':D')
Thanks for your time and info,
JJ Golden
petermontg
Post: # 20010Unread post petermontg
Thu Jun 07, 2012 5:36 am
JJ,
There is a Neumann callbration in manuals in the lathe trolls wiki. Has calibration for the BSB74. Hope it helps. It's in the navigation bar on right hand side.
Peter
Edit: link - http://lathetrolls.pbworks.com/w/browse/#view=ViewFolder&param=Neumann%20VMS%20Calibration%20Setup
Post: # 20013Unread post opcode66
Thu Jun 07, 2012 12:39 pm
That is the calibration instructions for the amp rack. Not for the BSB's. I don't think there is anything that you need to calibrate in the BSB's. If they are not responding equivalently send then pull them both and send the suspicous one back to Al. If something needs fixing in it, I don't think it is as simple as an adjustment to a pot or trimmer.
petermontg
Post: # 20016Unread post petermontg
Thu Jun 07, 2012 1:22 pm
Are last 2 pages not about BSB74?
Post: # 20017Unread post opcode66
Thu Jun 07, 2012 1:34 pm
Yes, they describe the function of the BSB and some of the maths behind knowing what acceptable Amps and Accelleration are. But, no instructions on how to "calibrate" them. Unlike the first few pages of the document which do contain specific instructions on how to calibrate the amp rack channels.
petermontg
Post: # 20018Unread post petermontg
Thu Jun 07, 2012 1:37 pm
Jasus, ya learn something new everyday. Fair play for spotting that.
jjgolden
Post: # 20019Unread post jjgolden
Thu Jun 07, 2012 1:57 pm
Thanks for chiming in guys.
Thanks Peter. I appreciate the effort.
If you remove one of these modules, you'll see all of the variable resistor trims pots there...all 13 of them!
If I had neumann extender cards and some info on the trim pots description, I believe I could do it... and hopefully learn something along the way.
JJG
Post: # 20020Unread post opcode66
Thu Jun 07, 2012 3:58 pm
You bought your lathe from Al, correct? Call him. My guess is that he will say the same thing I did. Send the module to him.
jjgolden
Post: # 20021Unread post jjgolden
Thu Jun 07, 2012 5:43 pm
Thanks Opcode,
Yes, Most roads lead to Grundy. :wink:
I like fishing for info here as well.
I'll keep you posted when I get it sorted.
Any additional info is always welcome!
JJG
Post: # 20022Unread post opcode66
Thu Jun 07, 2012 5:48 pm
I have a copy of the BSB74 schematics. Though schematics don't really tell you everything you need to know about proper usage/calibration... So, not sure what help they would be. I can send you a copy however.
Post: # 20023Unread post opcode66
Thu Jun 07, 2012 5:49 pm
I've been having better results doing the high frequency limiting elsewhere in my chain. I'm actually thinking about pulling mine out entirely.
jjgolden
Post: # 20024Unread post jjgolden
Thu Jun 07, 2012 6:00 pm
Thanks Opcode,
I've got the paper and the pdf schematics.
I de-ess in the signal chain, but I like to have the A.L. in the chain as a safety percussion.
JJG
Post: # 20025Unread post opcode66
Thu Jun 07, 2012 6:28 pm
I hear ya. I was the same way until recently.
Now, I just don't like the way things sound passing through the BSB. Maybe I am going overbaord here. But, I think I get better cuts doing the HFL elsewhere and not passing audio through the BSB's at all.
jjgolden
Post: # 20026Unread post jjgolden
Thu Jun 07, 2012 6:50 pm
If you run a tone through it, do you get any level difference between "Bypass" and "off"?
Post: # 20030Unread post opcode66
Thu Jun 07, 2012 10:21 pm
The documentation states that even in the Off position signal still passes through all the stages of the BSB. Why would I continue to do that if I'm not using them?
audadvnc
Post: # 20031Unread post audadvnc
Thu Jun 07, 2012 10:48 pm
Depends on whether the BSB uses a passive optocoupler (ex: Urei LA4, Westrex 1700 hi freq limiter) or a some active electronic stage like a VCA as its gain element (ex: dbx 160, Brooke Siren DPR402).
A limiter I built recently (to adjust mono/stereo mix of bass by level) uses a Vactrol optocoupler, which becomes an open, multi megohm resistor when dark and drops out of the circuit; only a few resistors remain, which attenuate but do not degrade the signal to any noticeable degree. I'm a big fan of Vactols; if you don't need instantaneous response or tight control of all parameters, they do not degrade signal when used as intended, and are simple to implement.
Voltage controlled amplifiers are by their nature going to be in the circuit all the time, and do add an additional layer of hoops for the signal to jump through on its way to the disk.
jjgolden
Post: # 20032Unread post jjgolden
Thu Jun 07, 2012 11:01 pm
@opcode
To see if it,s displaying level a difference....I,m not implying anything about how it,s used.
There,s a difference of about 1db between off and bypass on mine, which isn,t right.
Was wondering if your,s or anyone elses displayed similar differences.
I left a message with Al today.
JJG
Nickou
Post: # 20193Unread post Nickou
Sat Jun 23, 2012 5:37 am
I recalibrated mine after having changed all the IC and other little things ...
you need a scope and a sine generator and a extternal PSU ... if you have the shematics , look at them , and you will see than the audio path is clear .
It is easy to do , any good tech can do that ... no need to send that to Flozky , AL , or any specialist ...
As said opocode ,if you cut from digital there is others way to do it ...
so exept if you cut from tape , the best place for this machine is out of the rack !!
Post: # 20196Unread post opcode66
Sat Jun 23, 2012 8:51 pm
There is a trimmer labeled P12 (R53). It is a 5K linear. It sits just before R54 which is a 10k resistor. P12 sits between IC 5 and IC 9 which are N5556 op-amps. P12 is the Gain Trimmer. I think that is what you want to adjust.
jjgolden
Post: # 20206Unread post jjgolden
Mon Jun 25, 2012 2:41 pm
Thanks for the input guys.
Thanks Opcode, that's more what I was looking for.
In the end, I'm going to send it over to a guy with experience in
calibrating them.
Thanks again,
JJG
