Blurry Lines and Non maintained Depth
- johnoisamanc
I've been having a problem with one particular cut. Hopefully some more experienced guys can help.
VMS-80 cutting with preview played back from a DAW.
I'm getting badly formed grooves. The centre line in particular looked jagged. The stylus was recently changed (with a new one) and I cut a blank groove. all looking good. I also re-calibrated for the new stylus length.
What else should I look for? The heating temp seems all good.
I've also had some issues with min depth not being maintained. Once it was because the lacquer wasn't flat. I know the 80 has a very stable computer but could this be caused by fast stereo transients? Sticking in an EE doesn't seem to solve this particular job.
Thanks again for your wisdom
- concretecowboy71
Re: Blurry Lines and Non maintained Depth
Sounds like something broke the tip off the stylus or just a bad stylus. There have been a lot of issues lately poor quality from apollo. I started using Adamant.
No idea why it would not maintain min width...don't have a VMS80. Does it have a dash pot? If transients are causing the issue perhaps tightening the dash pot a bit would make it react a bit slower and not narrow up so fast.
Yes, I second the bad stylus batch issue...
Also, If it's a new stylus, you can give it a few hours to "Break in" and clean up.
I notice there's a typical time period between 4 and 10 hours where the bottom and sides of the groove start to clean up...
But not always...
JJG
But not always...
JJG
- Infrasonic Sound
The Transco stylus have been horrible. I've returned 5-6 of them in the last 2 months. Switched back to Adamants.
jjgolden wrote: I notice there's a typical time period between 4 and 10 hours where the bottom and sides of the groove start to clean up...
But not always...
JJG
I noticed it too
however...I don't like Adamant styli....so Transco is the only choice.
g
Alessandro Di Guglielmo
Mastering and Disk Cutting
