Neumann VA 62g Relays
petrolio
Post: # 42349Unread post petrolio
Fri May 06, 2016 1:43 pm
Hello trolls!
I'm trying to find a modern replacement for the old relays in the pitch control unit va62g
The brand is Gruner ref 955. Has someone already changed them?
Thanks
Inviato dal mio iPhone utilizzando Tapatalk
Re: Neumann VA 62g Relays
Post: # 42416Unread post mossboss
Tue May 10, 2016 3:17 pm
These are "modern" but get the ones that are with gold plated contacts available at RS in Milan Italy, dont choke at the price but, Ha
petrolio
Post: # 42427Unread post petrolio
Wed May 11, 2016 6:57 am
Thanks mossboss !!! The problem is that I can't get the right model number....not easy to find... :)
RS code is welcome.... :)
Post: # 42449Unread post mossboss
Thu May 12, 2016 6:39 am
Here you are in Italian as well ha
I did tell you don't choke at the price.
They will do the trick
petrolio
Post: # 42450Unread post petrolio
Thu May 12, 2016 6:40 am
Thanks Radardoug, this is a siemens type ... The gruner has only two row of pin... and a central screw....
Maybe i have to upgrade all the socket and relay...
