8 sided cardboard insert for packaging 14" lacquers
...like the ones that Apollo lacquers are shipped in. Does anyone have a source for these that they would like to share?
thanks,
-Kevin
thanks,
-Kevin
Re: 8 sided cardboard insert for packaging 14" lacquers
Lacquer companies contract with cardboard companies to make them custom. I would find out where they have them made and then ask if they take small orders of unprinted boxes (as all the ones for the lacquer companies will have transco or Apollo on them)
- Dub Studio
I get mine from http://www.protape.co.uk, not sure about Canada, good luck!
- philthelove
Hey Kevin, we are located in Montreal and worked with a company to make our own custom boxes.
They are not 8 sided but well built and have not had any problems with them. You can contact Le Lab Mastering for more info. Cheers, Phil
