Making a 12" lacquer
The_House_Records
Post: # 48793Unread post The_House_Records
Thu Dec 28, 2017 2:24 pm
Hi guys, just had a crazy idea. Because the audio engineers only use the first two inches of a 14" lacquer disk as a test cut, why couldn't you just make the test cut on a separate record instead, then only make a 12" stamper?
Let me know if this will work or not.
petermontg
Re: Making a 12" lacquer
Post: # 48799Unread post petermontg
Fri Dec 29, 2017 7:01 am
What is the mold going to grab onto if it's pressing a 12" record from a 12" stamper?
There is nothing for the stamper to be clamped in.
Best
Peter
Peter Montgomery
+353(0)894926271
The_House_Records
Post: # 48800Unread post The_House_Records
Fri Dec 29, 2017 8:13 am
Okay, that makes sense now.
jjgolden
Post: # 48803Unread post jjgolden
Fri Dec 29, 2017 12:51 pm
+ you need some working area when separating the metal from the lacquer after plating/forming:
See 1:16
https://www.youtube.com/watch?v=IReDh9ec_rk
Post: # 48835Unread post Aussie0zborn
Wed Jan 03, 2018 1:29 am
The stamper is clamped around the outside edge of the mould so it needs to be larger in diameter than the finished record.
CBS used 7" stampers and 12" stampers for 7" and 12" records respectively. This was due to the method they used for separating the record from the mould. Their stampers were not clamped but glued to the face of the mould. In any case, they cut on 10" lacquers for 7" pressings and 14" lacquers for 12" pressings.
