Cutterhead cooling gas-medical grade Helium
dcknuth
Post: # 49920Unread post dcknuth
Wed Mar 28, 2018 5:58 pm
Hello to all,
Has anyone else in the US experienced difficulties in obtaining Medical Grade Helium for cooling a cutterhead on a VMS-70? My gas supplier informs me that there is a new government restriction, and that it now requires a medical license to buy.. if you can even find it in stock. Any alternatives??
Thanks to all!
Re: Cutterhead cooling gas-medical grade Helium
Post: # 49924Unread post Aussie0zborn
Thu Mar 29, 2018 6:58 am
Not sure why you would want medical grade helium.
The Neumann manual recommends always buying the cheapest grade possible.
The helium simply fills a gap and helps to transfer the heat to other parts of the cutterhead.
dcknuth
Post: # 49926Unread post dcknuth
Thu Mar 29, 2018 8:24 am
Thank you for the reply AussieOzborn. I guess I've been under the belief that the cheaper helium contained moisture and other impurities that could conceivably contribute to corrosion inside the cutterhead.
I'm pleased to hear otherwise as I have plenty of other things to spend money on now with this project ☺️
Thanks again.
prof msg
Post: # 49953Unread post prof msg
Mon Apr 02, 2018 3:50 pm
I too have heard that balloon grade helium can contain moisture and ferrous debris that may be detrimental to the head. Is there a consensus about this? Is medical grade overkill?
-kp
evildrome
Post: # 50032Unread post evildrome
Tue Apr 10, 2018 9:10 am
Buy Helium for TIG (HELI_ARC) welding. It is five 9s dry (for the obvious reason that water f**ks with making a good weld).
It will not corrode any metal parts as it is used in hideously expensive metal welding equipment and the gas supplier does not want a queue of enraged welders at his door.
Probably best to avoid the balloon stuff as it could have anything in it.
Just google "welding gas supply helium <your local area> " where <your local area> is umm... your local area.
Cheers,
Wilson.
