I studied quite a bit in this great forum now and found the very useful thread of markrob about his DIY Recording Head: https://www.lathetrolls.com/viewtopic.php?f=15&t=3027.
I have some questions referring to the issues mentioned in this thread, but as it already is quite long and discusses various matters I thought I'd rather start a new thread for my kind of "basic" questions.
1) first problem: how to measure the head frequency response correctly?
My idea would have been, to record some piece of audio (either a generated frequency signal with range from maybe 20 hz up to 12000 hz or simply a music tune) with the recording head on polycarbonate and than play it back with input to True RTA with the "Peak hold" option. Then I would see the frequencies which were recorded. One would have the Anti RIAA filter in action while playing the record back, and this way the spectrum should be more or less a horizontal line until the upper frequency border, which would be depending on head quality somewhere between 8 and 12 kilo Hz (disregarding the resonance peak somewhere in the spectrum). Problem with this way of analyzing would be that undesired noise which was recorded and played back would be also in the analyzing spectrum.
In the above mentioned thread markrob writes that he used a "Kaman Eddy current position sensor" and obviously TrueRTA as software to measure.
I wonder how this works, I can't find out which kind of sensor model this should be and how to apply it to the recording head and what source signal to use.
How is the frequency plot in the post a displacement vs. frequency plot? As I understand the plot is a frequency response of some source signal sent to the head, right? But if it isn't played back with anti RIAA filter, why is the line so horizontal if the source signal was equalized?
2) second problem: with this kind of DIY-Stereo-Heads in combination with steel embossing styli, how would I want to record to achieve loudness?
a) Would I use as much weight as possible or as little as possible, or something in between (eg how many grams)? I can see a huge weight placed over on the head in the last picture of the first post in this thread?
Before, I thought I would use as little weight as possible to have the maximum of needle movement = amplitude = loudness?
b) Will I want to record really loud (just before the speaker will begin to distort)? I don't really understand the correlation of speaker wattage and amp wattage. In the used speakers in the thread are 5 watt speakers, but markrob uses 60 watts per speaker to record - is this due to equalizing anti RIAA, as to speek the low frequencies are cut out and the speaker is capable to take more watts? How do I know how much watts a speaker can take in correlation with equalizing?
3) third problem: How is the mentioned ferrofluid applied and used to damp the heads resonance?
I don't know anything about ferrofluids so far, as I understand it, it is a fluid which reacts to magnetism. How can one apply this to the speakers in the head? What kind of product would one buy?
Sorry for this kind of questions which might seem "rather dumb" to some of you..
budharpey
