Recorder control panel third generation video sound
https://youtu.be/YUHtIxiGAr4
Stereo Super sound , microphone records https://youtu.be/YUHtIxiGAr4
line input on pc [ net camera end line input pc ]
https://youtu.be/m8KdHDH0u9g
Re: Recorder control panel third generation video sound
that as well as, recorded on film, I had to do it the only way foto :
otherwise do, then you do not work properly ,,,
digital system
digital system
digital pnel
I did it without a circuit diagram, only experimentally
This is amazing!!
Compliments, a little complicated your circuit, but again compliments, bravo !
Generally, this can be replaced by a single rotary switch. I did it to see how it works in reality. The whole system of digital motor control, and the head does not improve the sound recordings. I had to use primitive Arduino microprocessor, but from my research resulted that these programmable integrated circuits have a great disadvantage at any time may cease to function properly and should be re-upload software, so is nonsense. Arduino is for fun.
Here it is used the old tried and tested system of digital CMOS circuits Motorolla MC, CD4 ..... etc. This integrated circuits professional, very cheap, very resistant to temperature changes and other factors.
This in no way improves the sound recordings, but makes life easier, it is harder to confuse what to do .....
there's more
there's more
Hi Sakuszi, I'm interested to see your progress.
I don't think arduino is nonsense, my system is very stable and uses software and arduino.
There are more and more professional and reliable products starting to show up using the arduino platform...
Here is an example.
http://controllino.cc/
James
Here is an example.
James
This is a small hot dog
recordboy , this is a small hot dog
They are talking about it on this film https://youtu.be/8EZaz_I0-RU
ok , full video record end reproduction https://youtu.be/HhFhaE6WE3cSillitoe wrote:Hi Sakuszi, I'm interested to see your progress.
Here is an example.
James
Nice one Sakuszi!
DPMCD (Direct plastic mastering compact disc)
