That's what I like to hear!! I am very stoked for you, James!! Thank you for keeping us updated along the waySillitoe wrote:Bahndahn, the hardware is over-engineered for the application.
Cheers!
LOLFlexinoodle wrote:after having a few emails back and forth with Sourri, i basically thought there was nothing else available, until i found this thread, that guy is one serious serious asshole, he really needs to grow up, he stopped corresponding with me because i asked if a cutter in Russia was using his cutter, who had been doing the Zare record releases because they were really good to use for scratch DJs. (and no, Germans are not generally like that, I have a lot of german mates, he is just a total asshole)
Perhaps the two systems are comparable as they are the only two lathe overhead systems on the market. Beyond that, there isn't much to compare!Sillitoe wrote:My system is different to the T560, but I understand why the comparison is made.
Sillitoe wrote: Sometimes it seems like it should be called the Beggars and Bitches forum
Awesome!!!Sillitoe wrote:New lathe cutting locked grooves here.
https://instagram.com/p/BJfp8F0B-FM/
Simply opened the ableton session that I had saved for locked grooves with the old lathe, loaded the eq presets for the Smokestack Lightning head, initialised USB communication with the lathe console, tweaked the head drop/lift timing and away it went!
Save session as a template for identical cuts in the future!
