Half scale VMS 70
evildrome
Half scale VMS 70
Post: # 57450Unread post evildrome
Mon Jan 04, 2021 4:44 pm
Hi All,
I wanted a VMS 70 but my budget does not stretch that far so I decided to make one.
I was thinking about it & all my machining equipment dates from the 50s to the 70s... which is VMS territory.
I think I'm about 75% of the way there.
Its half scale because my crucible isn't big enough to cast a full size VMS body and.... I don't have that much interest in cutting LPs anyway.
Cutting head wise, I'm going to have a go at making a KNOP REC1 as its the best documented head making thread on this forum.
Main spindle motor? No real firm decision yet. Might make one.
Cheers,
Wilson.
d
Re: Half scale VMS 70
Post: # 57454Unread post d
Tue Jan 05, 2021 1:41 am
hey! very nice machining!
did you do the Vtale linear slide yourself?
_______
dubcutter89
Post: # 57456Unread post dubcutter89
Tue Jan 05, 2021 3:13 am
New year but to me this already is the best DIY project 2021 :-)
Lukas
leemichael
Post: # 57458Unread post leemichael
Tue Jan 05, 2021 4:49 am
Following this thread like a mofo!
evildrome
Post: # 57459Unread post evildrome
Tue Jan 05, 2021 7:27 am
Yes ! Actually that was quite easy. The leadscrew for the vertical slide was actually the hardest part and machining the leadscrew nut.
evildrome
Post: # 57460Unread post evildrome
Tue Jan 05, 2021 7:42 am
This is a short video of my friend grinding the main dovetail ways.
My grinder is a bit small and moreover it is not automatic like his.
The Neumann VMS would have had it ways ground in a very similar manner on this sort of machine.
In keeping with the project this grinder also dates from the 70's :)
https://youtu.be/lTydad2PU5k
IMG_6225.MOV
evildrome
Post: # 57461Unread post evildrome
Tue Jan 05, 2021 7:54 am
Here I am machining the turntable:
https://youtu.be/NQrHJ5IwV-o
misjah
Post: # 57463Unread post misjah
Tue Jan 05, 2021 10:03 am
You will need a way to adjust the platter as it need to be ultra flat.
evildrome
Post: # 57464Unread post evildrome
Tue Jan 05, 2021 10:58 am
You mean with reference to the cutting head?
Yes. I was going to just make the spindle a good fit but now that you mention it... some adjustment capability would not hurt I suppose.
What adjustment facility did the VMS have?
Thanks,
Wilson.
misjah
Post: # 57469Unread post misjah
Tue Jan 05, 2021 1:02 pm
Vms has 2 platters...the top platter sits on 3 bolts in the bottom platter
evildrome
Post: # 57470Unread post evildrome
Tue Jan 05, 2021 1:49 pm
Interesting... and you can use the 3 bolts to level the top platter?
Man... I know that theoretically 3 point levelling systems are better than 4 point levelling systems ( 3 point cannot rock ) but actually using them is a total nightmare.
My tool makers microscope has a 3 point levelling system (its German, from the 40's) and it was horrible to get levelled.
It says "OMT" but its actually a re-badged Zeiss Jena microscope recovered as "spoils of war".
misjah
Post: # 57473Unread post misjah
Wed Jan 06, 2021 2:34 am
Takes practice but better than wobbly and unusable lathe ;)
dmills
Post: # 57489Unread post dmills
Sat Jan 09, 2021 7:21 am
There is a trick to a three point system.
Mount your dial indicator on the swan neck, and wind it in until it is at the same diameter as your three adjustment screws.
Rotate the platter until one of the screws is directly under the DTI probe, note reading, this is your reference.
Rotate to put next screw directly under the DTI, adjust to match reference reading.
Do this one more time for the third screw, then go back and check, but it should be job done.
Basically you use the fact that the point directly above and in line with the adjuster is controlled only by that adjuster, it is static with respect to the others.
Were I doing another platter I think I would probably place marks on the upper surface to make doing this easier.
Incidentally if doing the three point ball ended screw thing, bal-tec have some useful kinematic components. I would note that you really want two V blocks and a flat, not three V blocks (A mistake I made).
evildrome
Post: # 57511Unread post evildrome
Tue Jan 12, 2021 5:45 am
Thanks for the tips on setup.
My microscope has a levelling bubble which is hard to use.
Setting the bubble correctly means levelling to the floor, which may not be level with the table surface(!).
But for recording lathes you're setting the platter with reference to the cutting head so that's a great tip, thanks!
Cheers,
Wilson.
dmills
Post: # 57513Unread post dmills
Tue Jan 12, 2021 7:24 am
Having a fixed reference really helps.
One other thing to watch is that the cutting head needs to travel at an exact right angle to the spindle axis, otherwise the depth of cut changes with diameter.
On a VMS clone you could possibly tweak this out electronically using the depth control coil, but providing some reasonably convenient way to shim the thing might be worthwhile. My main ways (THK Cross roller bearings in mine) are mounted on a 'hinge' at one end with a 100tpi screw to trim this out.
Not having access to a decent machine shop at the moment (So envious!), my build is being based on used semiconductor fab photonics parts (Good source for really nice positioning slides and the like), and mostly a mix of ground flat stock and ally tooling plate (Because both are actually ground flattish from the factory).
The local water jet cutting place is getting far too much of my money.
Regards, Dan.
evildrome
Post: # 57515Unread post evildrome
Tue Jan 12, 2021 8:20 am
A bit of lead screw porn...
You can see the buttress thread form in this pic:
It was single point cut with a VNMG insert reground to a 45 degree buttress thread form.
evildrome
Post: # 57516Unread post evildrome
Tue Jan 12, 2021 8:41 am
Regards, Dan.
Good point.
Fortunately years of hoarding seemingly useless items has paid off.
This is an OMT 14" Optical Table. It looks like a rotary milling table but is it not.
It is a reference instrument for precise alignment of mirrors, lenses, lasers, and other optical components.
It is accurate to 1/3 of 1 arc second.
Which is probably a bit overkilly but it'll certainly do the job!
Speaking of useless... in the top right of the picture is the last Blume & Riedecker Mk4 coil winder in existence.
It winds basket weave coils which used to be necessary for radio equipment.
Sadly its function now is purely ornamental.
dmills
Post: # 57519Unread post dmills
Tue Jan 12, 2021 10:03 am
That coil winder might be of mainly historical interest for coils, but load it up with some aramid yarn and I bet you could get it to make small pressure vessels and maybe even things like wound high pressure tubes.
Besides, basket weave litz wound plate chokes are still a thing in some circles.
evildrome
Post: # 57521Unread post evildrome
Tue Jan 12, 2021 11:02 am
Oooh... that's an interesting idea. I have a load of kevlar offcuts from when I worked with some ballistic armour people (https://sarkartactical.com/)
You can pull threads off the edge quite easily before its embedded in resin or whatever.
Hmmm... anyone for a kevlar torque tube ?
dmills
Post: # 57522Unread post dmills
Tue Jan 12, 2021 11:43 am
Kevlar, carbon fibre, all sorts of things you can get as thread.
I sort of wonder about a basket wound voice coil, better cooling but unfortunately the fill factor would be horrible.
Back in the early days of firearms (Think early cannon) the wire wound barrel was actually a thing for a while, basically because wire was easier to inspect then castings made with really random metallurgy in an age before xray and ultrasonic flaw detectors.
