Presto leadscrew pin removal
Chuan
Post: # 65609Unread post Chuan
Wed Aug 28, 2024 1:11 am
Has anyone removed this pin? If so, how is it fixed?
Fela Borbone
Re: Presto leadscrew pin removal
Post: # 65611Unread post Fela Borbone
Wed Aug 28, 2024 3:34 am
...it was not epoxi, but aged grease solidified...
Chuan
Post: # 65612Unread post Chuan
Wed Aug 28, 2024 3:43 am
Sorry, I should have been clearer. This tiny pin that turns the screw from either end (see photo)
Fela Borbone
Post: # 65615Unread post Fela Borbone
Wed Aug 28, 2024 2:45 pm
Ah, ok,
This I dont know how/if can be removed and placed back.
apoklis
Post: # 65619Unread post apoklis
Fri Aug 30, 2024 10:55 am
no don't remove , or why remove . The clutch has a pressed gear in side . It brass and it you split it while taking it apart , Is not fixable. Maybe jb weld but its not good. What is wrong with the pin?
If it wont move , free it with carb cleaner or paint thinner . All metal parts wont hurt it. But avoid taking it apart
piaptk
Post: # 65620Unread post piaptk
Sat Aug 31, 2024 1:57 am
I agree with Al.
The pin will just come out with pliers (it happens to the clutch and crank pin accidentally fairly often). But why would you intentionally want to do it?
