farmersplow
Post: # 68564Unread post farmersplow
Fri Dec 19, 2025 3:52 pm
The housing - completion:
I printed out some nice lettering using a foil plotter. And a logo.
I then attached this all around the housing.
I like it this way.
Greetings from Austria,
Thomas
farmersplow
Post: # 68574Unread post farmersplow
Sun Dec 21, 2025 12:29 pm
The wedding:
Here is a short video. I recorded the assembly of the housing with the lathe for you in fast motion.
In real time, the entire assembly took about 15 minutes.
Here is the video:
121 video Hochzeit.mp4
So now everything is fully assembled.
I took a few more photos (assembled), which I will post as soon as I have time to sort through them all.
All in all, the assembly went well. Since everything was well planned, every screw fit perfectly and it works flawlessly.
Thomas
displacedsnail
Post: # 68575Unread post displacedsnail
Sun Dec 21, 2025 2:23 pm
Now that's what I call giving the people what they want! Absolutely gorgeous. I couldn't conceptualize how the housing would fit the machine, but wow. It must have felt very satisfying to slide it over the machine. Congratulations!
zdenek
Post: # 68578Unread post zdenek
Sun Dec 21, 2025 4:33 pm
Respect.
Everything's put together.
Now I'm just waiting for YouTube and the video of the recordings.
It would be useful to have handles for carrying a vinyl recorder, like those found on the Vestax VRX2000, etc. :)
farmersplow
Post: # 68587Unread post farmersplow
Tue Dec 23, 2025 7:10 am
Satisfying? I can't even begin to describe how satisfying it was!
farmersplow
Post: # 68588Unread post farmersplow
Tue Dec 23, 2025 7:23 am
Respect.
Carrying handles? The Vestax is nothing like my lathe. The VRX2000 weighs just 26 kg. The designer who came up with these monstrous handles must have been on drugs. My device weighs about 70 kg and cannot be carried by one person. (More like two or four people). I developed removable carrying bars for transport. After transport, the openings are closed with plugs.
I don't post on YouTube. The rules for publishing music there are too strict.
farmersplow
Post: # 68589Unread post farmersplow
Tue Dec 23, 2025 7:34 am
Here are a few pictures of the entire lathe.
Thomas
Fela Borbone
Post: # 68590Unread post Fela Borbone
Tue Dec 23, 2025 9:55 am
Maximun respect, Sir.
FILMTOOLS
Post: # 68594Unread post FILMTOOLS
Wed Dec 24, 2025 5:54 am
WoW Thomas! What a beautiful work of art!
zdenek
Post: # 68606Unread post zdenek
Sat Dec 27, 2025 10:10 am
When I first started experimenting, I also recorded other people's voices, singers' voices, and other people's music. Now I don't do that anymore because I record my own voice first, so no one can accuse me of plagiarism, which is subject to copyright. It's as simple as recording vinyl records: record your voice and upload it to YouTube, just like Thomas Edison did, recording his voice on a cylinder covered with gold foil. It would be something to hear your voice recorded on your recorder, wouldn't it? :)
It's very easy to determine your device's parameters, etc. It's best to record using the line-out (not the microphone) from your recorder to your computer's line-in, but that's up to you. I post my recordings on YouTube and no one has blocked me so far.
The guy who has the VRX2000 also records videos using the line-out and line-in, and no one has blocked him either.
Unless there's something you can't say. :)
vrx2000 https://www.youtube.com/watch?v=n3oCMl1Oksg
sameal
Post: # 68665Unread post sameal
Mon Jan 05, 2026 10:12 am
It's been awhile since I checked in on this thread.
That lathe is amazing!
C4ND1M4N
Post: # 68679Unread post C4ND1M4N
Wed Jan 07, 2026 12:25 am
Wow this is really cool!
discosdecorte
Post: # 68685Unread post discosdecorte
Wed Jan 07, 2026 12:58 pm
Beautiful 😍
farmersplow
Post: # 68708Unread post farmersplow
Fri Jan 09, 2026 8:22 am
Fela Borbone
FILMTOOLS
sameal
C4ND1M4N
discosdecorte
Thank you very much for your positive feedback!
farmersplow
Post: # 68709Unread post farmersplow
Fri Jan 09, 2026 8:34 am
Before I start recording, I always play the piece of music in the range with the highest peaks and check the deflection level to make sure everything is OK.
The music must be clearly audible at the cutting head, the level indicator should not exceed 0dB, and the peak indicator should not remain lit continuously.
vid 122_01_8.mp4
Best regards from Austria,
Thomas
Semar
Post: # 68725Unread post Semar
Sun Jan 11, 2026 3:30 am
All my respect Thomas !
rubenr
Post: # 68743Unread post rubenr
Tue Jan 13, 2026 1:08 pm
Bist du narish oita!!! Super desing, super aspect, i+d and a lot creativity ! Verkaufst du 3 und kauf eine profi cutterhead ! Gratuliere !!!!
farmersplow
Post: # 68773Unread post farmersplow
Sun Jan 18, 2026 3:19 am
Thank you, my faithful companion of many years.
farmersplow
Post: # 68774Unread post farmersplow
Sun Jan 18, 2026 3:26 am
Echt oarg oida! :D Thank you very much! I'm glad you like it. After all, you cut with your eyes too. :lol:
