Who can help me with my VR T560 cutterhead?
Re: Who can help me with my VR T560 cutterhead?
My mini-router dremel tool came with a bunch of different bits, one of them looks like this:
This kind of thing might work?
What is the taper angle on those styli?
It is made of titanium for German knives,
I thought over this week as you do with this material [titanium, titanium can be soldered tin]. I've been doing this handle on the knife 10 minutes.
titanum , diamond knife
for sale $ 0.1 cents, plus shipping $ 2.5
saku k h
- Snug Music
Hey, ..Thelurker wrote:Good thread! I also experienced this exact same problem earlier last year....Souri head blew on one side for no reason, then while trying to troubleshoot the other side went to 1ohm!
Are the original Souri tweeters 4ohm?
Hey Scott! Can upload a high quality recording or video of a cut from the redcar tweeters?
Yes Souris are exactly 4 ohms!
Redcar also 4 ohms and at the back (just like Souri), the m4 thread mount! )
but you must be careful!
Look before the Tweeter on how they are glued to the housing !!!
Possibly, out and re-glue!
Ordered you best several, so you can assisst between them!
(If you sticking too much makes processing!)
If you glued the cone, be careful, take care that nothing gets on the rubber mount of Mebran !!!
Ps: I'll make you some Records-Wav / video ready to show how the head works with the tweeters and how the quality is, ..'m just a little bit at the moment struck by cold and fever
regards Scotty
Yes, are sicurely the same tweeters, Phonocar 2/419 model.
I am too interested to see your videos about as these speakers works.
- Snug Music
hey Orp,.studiorp wrote:Yes, are sicurely the same tweeters, Phonocar 2/419 model.
YES..it is!!!
here is my rebuild Head with Phonocar Tweeter
Regards Scotty
- Snug Music
Works perfectly!!!
Snug Music wrote:Works perfectly!!!![]()
This is great ! I quickly hear the recording!
Very good work and fast, perfect!
How are the high frequencies? It seems like that screw you have holding the stylus would add a bit of mass
wait for resultsaaron wrote:How are the high frequencies? It seems like that screw you have holding the stylus would add a bit of mass
- Snug Music
Hey,..the hights are very good,..but thats right,..i must change the equilization range in high.
Thats a result of the stylusholder...i will change it and will take an diamond-stylus 340P.
I must make an holder for them!
Tomorow i will change it...
Momently im little bit down ( have a virusinfection )
sorry that im momently not so fast..
Tomorow i will make records and than i will post it here...stay tuned
Scotty
Scotty
- Snug Music
ps: though I had to slightly raise the heights for the Holder, I am still surprised by the positive result. did not think that the working head as well!
Very awesome, inspiring work!
- Snug Music
Thanks Aaron, am .. as I said a little ill (virus!), it's even better to reproduce this head. will all make the day when I am healthy again! then will test other tweeters and compare which ones are good and which bad! as I said, the next day I'll take that in attack and inform you.aaron wrote:Very awesome, inspiring work!
Scotty
Thanks for the reply ScottSnug Music wrote:Hey, ..Thelurker wrote:Good thread! I also experienced this exact same problem earlier last year....Souri head blew on one side for no reason, then while trying to troubleshoot the other side went to 1ohm!
regards Scotty![]()
Just to clarify, the original Souri teeeters have a silver titanium dome and these redcar ones have silk done??is the dome soft or hard?
Also when you say to order several, are the domes glued bad from factory? We have to remove and reinstall dome?
Did you have an original Souri head or just built one from this thread?
- Snug Music
yes .. these tweeter Not original souri-tweeter! the original tweeter have a titanium membrane! I have this tweeter chosen because they have a good value! which is membrane soft and needs of the cone with 2K overlglue (only the membrane, not the rubber suspension) ...but be careful! then the cone carefully stick! then 2k form imprint rubber emphasize the cone. that was all! the head I built ... have no head original souri. I have rebuild the head by Markct postings.
So,..thats all for tonight...see ya tomorrow...
Best regards Scotty
Best regards Scotty
Hey sakuszi, cool part!! Where did you find this? Do you have a link?sakuszi wrote:It is made of titanium for German knives,
I thought over this week as you do with this material [titanium, titanium can be soldered tin]. I've been doing this handle on the knife 10 minutes.![]()
I did this handle a drill and a sander, reamer diamond, diamond-dustedBahndahn wrote:Hey sakuszi, cool part!! Where did you find this? Do you have a link?sakuszi wrote:It is made of titanium for German knives,
something recorded?Snug Music wrote:Works perfectly!!!![]()
